Datasheet HMC713MS8, 713MS8E (Analog Devices) - 7
Description54 dB, LOGARITHMIC DETECTOR / CONTROLLER, 45 - 2700 MHz
Pages / Page10 / 7 — HMC713MS8 / 713MS8E. 54 DB, LOGARITHMIC. DETECTOR / CONTROLLER, 45 - 2700 …
File Format / SizePDF / 956 Kb
HMC713MS8 / 713MS8E. 54 DB, LOGARITHMIC. DETECTOR / CONTROLLER, 45 - 2700 MHz. Pin Descriptions
HMC713MS8 / 713MS8E 54 DB, LOGARITHMIC DETECTOR / CONTROLLER, 45 - 2700 MHz Pin Descriptions
HMC713MS8 / 713MS8E
v06.0412
Pin Number Function Description Interface Schematic t M s - 1 INP rF input pin. rs o t c e t e enable pin. D Apply VeN >0.8 x Vcc for normal operation. Apply VeN <0.2xVcc to disable the HMc713Ms8e and r reduce supply current to 0.3mA. 2 eN e to ensure proper start-up apply the power-up sequence w shown in the “Power-Up timing Diagram” attached to the application circuit. o P set point input for controller mode. 3 Vset connect to oUt with the resistor network shown in evaluation board drawing for detector mode. connection for ground referenced external lowpass 4 cLPF filter capacitor. 5 GND Device ground. I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
