Datasheet HMC600LP4, 600LP4E (Analog Devices) - 8
Description75 dB LOGARITHMIC DETECTOR / CONTROLLER 50 - 4000 MHz
Pages / Page8 / 8 — HMC600LP4 / 600LP4E. 75 dB LOGARITHMIC. DETECTOR / CONTROLLER 50 - 4000 …
File Format / SizePDF / 510 Kb
HMC600LP4 / 600LP4E. 75 dB LOGARITHMIC. DETECTOR / CONTROLLER 50 - 4000 MHz. Application & Evaluation PCB Schematic
HMC600LP4 / 600LP4E 75 dB LOGARITHMIC DETECTOR / CONTROLLER 50 - 4000 MHz Application & Evaluation PCB Schematic
HMC600LP4 / 600LP4E
v02.0909
12 T S - SM R O T Notes C E Note 1: The HMC600LP4 & HMC600LP4E evaluation boards are pre-assembled for single-ended input, and detector/RSSI mode. T Note 2: For single-ended input operation, use the INP port and make no connection to INN. INN is AC coupled to ground by C2 E Note 3: For differential input, remove C2, and install a 1000pF capacitor in series with INN at location shown. Note 4: For detector mode, connect high impedence volt meter to the LOGOUT port, and make no connection to VSET. LOGOUT R D is shorted to VSET by R3, as required for detector mode. E Note 5: For controller mode, remove R3 and make appropriate connection to LOGOUT and VSET. In controller mode, the W LOGOUT output can be used to drive a variable gain amplifi er, or a variable attenuator, either directly or through a buffer O or microcontroller. VSET should be connected to an external supply, typically between +0.6 and +1.9V. P
Power-Up Timing Diagram
Information furnis F heod r pri by An ce, de alog Devi lcievs eir s y b , a eliev nd to pla ed to be accu ce o rate anrder d relia sbl, pl e. H ease co owever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone: 978 rights of third parties that may result from its use. Specifications subject to change without notice. No Ph - o 25 ne 0 : 7 -3 81- 3 3 4 29 3 F -470 ax: 978 0 • Orde - r o 25 nlin 0- e a3 t 373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
12 - 9
Order On-l Trademarks and registered trademarks are the property of their respective owners. ine at www.hit A ti p te.co plicati m on Support: Phone: 1-800-ANALOG-D
