1 MHz TO 8 GHz, 70 dB Logarithmic Detector/Controller
Pages / Page
24 /10 — AD8318. Data Sheet. j0.5. 10k. RF OFF. j0.2. ) z H V/ n Y (. 0.2. 0.5. …
Revision
D
PDF / 2.9 Mb
AD8318. Data Sheet. j0.5. 10k. RF OFF. j0.2. ) z H V/ n Y (. 0.2. 0.5. 0.1GHz. –60dBm. 8GHz. –40dBm. D L. –20dBm. 5.8GHz. 0.9GHz. –j0.2. EC 100. 1.9GHz. ISE SP
AD8318Data Sheetj1j2j0.510kRF OFFj0.2) z H V/ n Y (1kT00.20.512SI0.1GHz–60dBm8GHzEN–40dBmD L–20dBmA5.8GHzR0.9GHzT–j0.2EC 1001.9GHzISE SP–10dBmO3.6GHz2.2GHzN0dBm 8 01 3- –j0.5–j2 85 04 5 10 01 1310301003001k3k10k 3- START FREQUENCY = 0.1GHz 85 STOP FREQUENCY = 8GHz–j1FREQUENCY (kHz) 04 Figure 16. Input Impedance vs. Frequency; No Termination Resistor on Figure 19. Noise Spectral Density of Output; CLPF = Open INHI, ZO = 50 Ω 0.071k0.06) z H V/0.05nA) (Y ( TNTSI0.04DECREASING VENRREENBLINCREASING VENBLD 100LCUA0.03YRLTPECUP S 0.02ISE SP O0.01N 9 16 0 01 3- 3- 85 85 0 04 10 04 1.41.51.61.71.81310301003001k3k10kVENBL (V)FREQUENCY (kHz) Figure 17. Supply Current vs. Enable Voltage Figure 20. Noise Spectral Density of Output Buffer (from CLPF to VOUT); CLPF = 0.1 μF 2.22.02.01.6VOUT1.81.21.60.8200mV/VERTICALDIVISION1.40.4)B) d(V T 1.20R (OUV 1.0–0.4RRO EPULSED RF INPUT 0.1GHz,0.8–0.8–10dBmGND0.6–1.20.4–1.6 0 02 7 3- -01 85 3 0.2–2.0 04 85 –65–55–45–35–25–15–5515 04 20ns PER HORIZONTAL DIVISIONPIN (dBm) Figure 18. VOUT Pulse Response Time; Pulsed RF Input 0.1 GHz, –10 dBm; Figure 21. Output Voltage Stability vs. Supply Voltage at 1.9 GHz CLPF = Open When VP Varies by 10%, Multiple Devices Rev. D | Page 10 of 24 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Using the AD8318 Basic Connections Enable Interface Input Signal Coupling Output Interface Setpoint Interface Temperature Compensation of Output Voltage Temperature Sensor Measurement Mode Device Calibration and Error Calculation Selecting Calibration Points to Improve Accuracy over a Reduced Range Variation in Temperature Drift from Device to Device Temperature Drift at Different Temperatures Setting the Output Slope in Measurement Mode Response Time Capability Output Filtering Controller Mode Characterization Setup and Methods Evaluation Board Outline Dimensions Ordering Guide
