Bidirectional, Zero-Drift, Current Sense Amplifier
Pages / Page
18 /9 — Data Sheet. AD8418A. 2.7V. A 40. –50. –100. EN R. F E ) –150. R 30. (m …
Revision
E
PDF / 463 Kb
Data Sheet. AD8418A. 2.7V. A 40. –50. –100. EN R. F E ) –150. R 30. (m –200. E A. G R –250. T U 20. IVE. LTA. –300. U 15. T U POSIT –350. IMU. –400. –450. –500
Data SheetAD8418A4502.7V)5VA 40–50(mMT–10035ROEN RF E ) –150R 30VUNGC(m –200KIL25RAINE ASG R –250T U 20IVEPLTATO–300U 15VOT U POSIT –350MP10TIMU–400XOUMA5–4500–500–40 –25 –105203550658095110 125 -019 012345678910 021 TEMPERATURE (°C) 11883 OUTPUT SOURCE CURRENT (mA) 11883- Figure 22. Maximum Output Sink Current vs. Temperature Figure 24. Output Voltage Range from Positive Rail vs. Output Source Current 40)300)VA(m35(mDT250UNENOR 30RR U5VGCM200E 25CRORFU2.7VEO 20150S TANGURP 15ETGU100O 10LTAMO VMUT50XI5UMATP OU00–40 –25 –105203550658095110 125 020 012345678910 022 3- TEMPERATURE (°C) 883- 1188 OUTPUT SINK CURRENT (mA) 11 Figure 23. Maximum Output Source Current vs. Temperature Figure 25. Output Voltage Range from Ground vs. Output Sink Current Rev. E | Page 9 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION OUTPUT OFFSET ADJUSTMENT UNIDIRECTIONAL OPERATION Ground Referenced Output Mode VS Referenced Output Mode BIDIRECTIONAL OPERATION EXTERNAL REFERENCED OUTPUT SPLITTING THE SUPPLY SPLITTING AN EXTERNAL REFERENCE APPLICATIONS INFORMATION MOTOR CONTROL 3-Phase Motor Control H-Bridge Motor Control SOLENOID CONTROL High-Side Current Sense with a Low-Side Switch High-Side Current Sense with a High-Side Switch High Rail Current Sensing PINOUT OPTION ENGINEERED FOR FMEA OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
