link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 16 link to page 11 link to page 12 link to page 12 AD8278/AD8279SPECIFICATIONS VS = ±5 V to ±15 V, VREF = 0 V, TA = 25°C, RL = 10 kΩ connected to ground, G = ½ difference amplifier configuration, unless otherwise noted. Table 2.G = ½Grade BGrade AParameter ConditionsMin TypMax Min TypMaxUnit INPUT CHARACTERISTICS System Offset1 50 100 50 250 μV Over Temperature TA = −40°C to +85°C 100 250 μV vs. Power Supply VS = ±5 V to ±18 V 2.5 5 μV/V Average Temperature Coefficient TA = −40°C to +85°C 0.3 1 2 5 μV/°C Common-Mode Rejection VS = ±15 V, VCM = ±27 V, Ratio (RTI) RS = 0 Ω 80 74 dB Input Voltage Range2 −3 (VS + 0.1) +3 (VS − 1.5) −3 (VS + 0.1) +3 (VS − 1.5) V Impedance3 Differential 120 120 kΩ Common Mode 30 30 kΩ DYNAMIC PERFORMANCE Bandwidth 1 1 MHz Slew Rate 1.1 1.4 1.1 1.4 V/μs Channel Separation f = 1 kHz 130 130 dB Settling Time to 0.01% 10 V step on output, CL = 100 pF 9 9 μs Settling Time to 0.001% 10 10 μs GAIN Gain Error 0.005 0.02 0.01 0.05 % Gain Drift TA = −40°C to +85°C 1 5 ppm/°C Gain Nonlinearity VOUT = 20 V p-p 7 12 ppm OUTPUT CHARACTERISTICS Output Voltage Swing4 VS = ±15 V, RL = 10 kΩ TA = −40°C to +85°C −VS + 0.2 +VS − 0.2 −VS + 0.2 +VS − 0.2 V Short-Circuit Current Limit ±15 ±15 mA Capacitive Load Drive 200 200 pF NOISE5 Output Voltage Noise f = 0.1 Hz to 10 Hz 1.4 1.4 μV p-p f = 1 kHz 47 50 47 50 nV/√Hz POWER SUPPLY6 AD8278 Supply Current 200 200 μA Over Temperature TA = −40°C to +85°C 250 250 μA AD8279 Supply Current 300 350 300 350 μA Over Temperature TA = −40°C to +85°C 400 400 μA Operating Voltage Range7 ±2 ±18 ±2 ±18 V TEMPERATURE RANGE Operating Range −40 +125 −40 +125 °C 1 Includes input bias and offset current errors, RTO (referred to output). 2 The input voltage range may also be limited by absolute maximum input voltage or by the output swing. See the Input Voltage Range for details. 3 Internal resistors are trimmed to be ratio matched and have ±20% absolute accuracy. 4 Output voltage swing varies with supply voltage and temperature. See Figure 22 through Figure 25 for details. 5 Includes amplifier voltage and current noise, as well as noise from internal resistors. 6 Supply current varies with supply voltage and temperature. See Figure 26 and Figur for e 28 details. 7 Unbalanced dual supplies can be used, such as −VS = −0.5 V and +VS = +2 V. The positive supply rail must be at least 2 V above the negative supply and reference voltage. Rev. C | Page 3 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION SHORT-CIRCUIT CURRENT ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT INFORMATION DC Performance AC Performance DRIVING THE AD8278 AND AD8279 INPUT VOLTAGE RANGE POWER SUPPLIES APPLICATIONS INFORMATION CONFIGURATIONS DIFFERENTIAL OUTPUT INSTRUMENTATION AMPLIFIER OUTLINE DIMENSIONS ORDERING GUIDE
