20 /9 — Data Sheet. AD8270. 120. ISHORT+. GAIN = 2. 100. A) m. GAIN = 1. RRE. d ( …
Revision
A
PDF / 469 Kb
Data Sheet. AD8270. 120. ISHORT+. GAIN = 2. 100. A) m. GAIN = 1. RRE. d ( –5. GAIN = 0.5. CU T. IN GA. CUI. –20. –10. –40. –60. SHORT–. HO S. –15. –80. –100. –120. 10k
Data SheetAD827010120ISHORT+GAIN = 2100580A) m60(GAIN = 1T0N40)RREB20d ( –5GAIN = 0.5CU T0IN GACUI–20IR–10-C–40RTI–60SHORT–HO S–15–80–100–20–120 21 1001k10k100k1M10M100M 18 0 0 –40–20020406080100120 9- 9- 97 FREQUENCY (Hz) 97 TEMPERATURE (°C) 06 06 Figure 16. Gain vs. Frequency Figure 19. Short-Circuit Current vs. Temperature 100+VS+125°C90GAIN = 2, 0.5+V80S – 2GAIN = 1)–40°C+25°C+85°CG (V70IN +VS – 4W60SB)EdG50A0RR (LT O+125°CCM 40V T+85°CU –VS + 230TP+25°C20OU –VS+ 410–40°C0 9 –VS 2 101001k10k100k1M10M 01 2001k10k 02 9- 9- FREQUENCY (Hz) 97 97 RLOAD (Ω) 06 06 Figure 17. CMRR vs. Frequency Figure 20. Output Voltage Swing vs. RLOAD 0+VS–40°CCROSSTALK (G = 1)+25°C–20+VS – 3)B)V (–40(dGNIN +VS – 6IOW+125°C–60S+85°CEARAT PAG0ET LS –80OLVNE+125°CUT –VS + 6–100P+85°CUTCHANO+25°C–120–VS + 3–40°C–140–VS101001k10k100k 13 3 0 020406080100 9- -02 FREQUENCY (Hz) 97 79 06 CURRENT (mA) 69 0 Figure 18. Channel Separation vs. Frequency Figure 21. Output Voltage Swing vs. Current (IOUT) Rev. A | Page 9 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DIFFERENCE AMPLIFIER CONFIGURATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT INFORMATION DC Performance AC Performance Production Costs Size DRIVING THE AD8270 PACKAGE CONSIDERATIONS POWER SUPPLIES INPUT VOLTAGE RANGE APPLICATIONS INFORMATION DIFFERENCE AMPLIFIER CONFIGURATIONS SINGLE-ENDED CONFIGURATIONS Gain of 1 Configuration DIFFERENTIAL OUTPUT DRIVING AN ADC DRIVING CABLING OUTLINE DIMENSIONS ORDERING GUIDE
