16 /6 — AD629. TYPICAL PERFORMANCE CHARACTERISTICS. 100. 400. ) B. 360. TA = …
Revision
C
PDF / 413 Kb
AD629. TYPICAL PERFORMANCE CHARACTERISTICS. 100. 400. ) B. 360. TA = +25°C. O (. 320. 280. ION. A = +85°C. LTAG. 240. O V. TA = –40°C. JE E. 200. 160. N O. 120
AD629TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15 V, unless otherwise noted. 100400) B90360dTA = +25°CO (80)320TI±VA(R70E280TIONA = +85°CT60LTAG240CO VTA = –40°CJE E50200DEROE40-M160ODN O-M30M120MON M20CO80OM C10 06 40 09 0 0 3- 3- 78 78 0 00 0 00 1001k10k100k1M10M02468101214161820FREQUENCY (Hz)POWER SUPPLY VOLTAGE (±V) Figure 7. Common-Mode Rejection Ratio vs. Frequency Figure 10. Common-Mode Operating Range vs. Power Supply Voltage 2mV/DIVRL = 10kΩRL = 2kΩVS = ±18V)VS = ±18V)IVIV/D/D V(2mV(2mVS = ±15VRVS = ±15VR O RRROREE TUTUPVS = ±12VTVS = ±12VTPU OOU 7 0 00 V4V/DIV 01 VS = ±10VS = ±10V4V/DIV 3- 3- 78 78 00 00 –20–16–12–8–4048121620–20–16–12–8–4048121620VOUT (V)VOUT (V) Figure 8. Typical Gain Error Normalized @ VOUT = 0 V and Output Voltage Figure 11. Typical Gain Error Normalized @ VOUT = 0 V and Output Voltage Operating Range vs. Supply Voltage, RL = 10 kΩ (Curves Offset for Clarity) Operating Range vs. Supply Voltage, RL = 2 kΩ (Curves Offset for Clarity) RL = 1kΩVS = ±5V, RL = 10kΩ)V)IVS = ±18VIV/D/D(2mVVS = ±15V(2mVVRRS = ±5V, RL = 2kΩRRORROEEUTUTPVPVTS = ±12VTS = ±5V, RL = 1kΩUUOO 8 1 1 00 VS = ±10V4V/DIV 0 V 3- S = ±2.5V, RL = 1kΩ1V/DIV 3- 78 78 00 00 –20–16–12–8–4048121620–20–16–12–8–4048121620VOUT (V)VOUT (V) Figure 9. Typical Gain Error Normalized @ VOUT = 0 V and Output Voltage Figure 12. Typical Gain Error Normalized @ VOUT = 0 V and Output Voltage Operating Range vs. Supply Voltage, RL = 1 kΩ (Curves Offset for Clarity) Operating Range vs. Supply Voltage (Curves Offset for Clarity) Rev. C | Page 6 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS BASIC CONNECTIONS SINGLE-SUPPLY OPERATION SYSTEM-LEVEL DECOUPLING AND GROUNDING USING A LARGE SENSE RESISTOR OUTPUT FILTERING OUTPUT CURRENT AND BUFFERING A GAIN OF 19 DIFFERENTIAL AMPLIFIER ERROR BUDGET ANALYSIS EXAMPLE 1 ERROR BUDGET ANALYSIS EXAMPLE 2 OUTLINE DIMENSIONS ORDERING GUIDE
