Datasheet AMP03 (Analog Devices) - 5
Description | Precision, Unity-Gain Differential Amplifier |
Pages / Page | 8 / 5 — AMP03. 0.003. VS =. 15V. S = 0. S =. RL = 2k. 0.002. 0.001. 0.000. GAIN … |
Revision | F |
File Format / Size | PDF / 269 Kb |
AMP03. 0.003. VS =. 15V. S = 0. S =. RL = 2k. 0.002. 0.001. 0.000. GAIN ERROR (%) –0.001. SLEW RATE (V/ 8. SUPPLY CURRENT (mA). –0.002. –0.003
AMP03 0.003 13 6 VS =
ⴞ
15V VS =
ⴞ
15V R V S = 0
S =
ⴞ
15V RL = 2k
0.002 12 5 11 0.001 s)
4 10 0.000 3 9 GAIN ERROR (%) –0.001 2 SLEW RATE (V/ 8 SUPPLY CURRENT (mA) –0.002 1 7 –0.003 6 0 –75 –50 –25 0 25 50 75 100 125 150 –75 –50 –25 0 25 50 75 100 125 –75 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (
ⴗ
C) TEMPERATURE (
ⴗ
C) TEMPERATURE (
ⴗ
C)
TPC 10. Gain Error vs. Temperature TPC 11. Slew Rate vs. Temperature TPC 12. Supply Current vs. Temperature
4 17.5 –17.5 TA = +25
ⴗ
C TA = +25
ⴗ
C V V S =
ⴞ
18V S =
ⴞ
18V 15.0 –15.0 3 V V 12.5 S =
ⴞ
15V –12.5 S =
ⴞ
15V 10.0 V –10.0 V S =
ⴞ
12V S =
ⴞ
12V 2 7.5 –7.5 VS =
ⴞ
9V VS =
ⴞ
9V 5.0 –5.0 SUPPLY CURRENT (mA) 1 V 2.5 V MAXIMUM OUTPUT VOLTAGE (V) S =
ⴞ
5V –2.5 MAXIMUM OUTPUT VOLTAGE (V) S =
ⴞ
5V TA = +25
ⴗ
C 0 0 0 0
ⴞ
5
ⴞ
10
ⴞ
15
ⴞ
20 0 6 12 18 24 30 36 0 –2 –4 –6 –8 –10 –12 SUPPLY VOLTAGE (V) OUTPUT SOURCE CURRENT (mA) OUTPUT SINK CURRENT (mA)
TPC 13. Supply Current vs. Supply TPC 14. Maximum Output Voltage TPC 15. Maximum Output Voltage Voltage vs. Output Current (Source) vs. Output Current (Sink)
120 TA = +25
ⴗ
C VS =
ⴞ
15V Hz) 100 80 +1
V +10
V 60 0V 0V –1
V –10
V 40 20 VOLTAGE NOISE DENSITY (nV/ 0 NOTE: EXTERNAL AMPLIFIER GAIN = 1000; 1 10 100 1k 10k 0.1 TO 10Hz PEAK-TO-PEAK NOISE THEREFORE, VERTICAL SCALE = 10
V/DIV. FREQUENCY (Hz)
TPC 16. Voltage Noise Density vs. TPC 17. Low Frequency Voltage TPC 18. Voltage Noise from 0 kHz Frequency Noise to 1 kHz
+10
V 0V –10
V NOTE: EXTERNAL AMPLIFIER GAIN = 1000; THEREFORE, VERTICAL SCALE = 10
V/DIV.
TPC 19. Voltage Noise from 0 kHz to 10 kHz REV. F –5– Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PIN CONNECTIONS SPECIFICATIONS WAFER TEST LIMITS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE DICE CHARACTERISTICS BURN-IN CIRCUIT SLEW RATE TEST CIRCUIT Typical Performance Characteristics APPLICATION CIRCUITS APPLICATIONS INFORMATION MAINTAINING COMMON-MODE REJECTION OUTLINE DIMENSIONS Revision History
