Datasheet AD5520 (Analog Devices)
Description | Per Pin Parametric Measurement Unit/Source Measure Unit |
Pages / Page | 24 / 1 — Per Pin Parametric. Measurement Unit/Source Measure Unit. AD5520. … |
Revision | B |
File Format / Size | PDF / 520 Kb |
Per Pin Parametric. Measurement Unit/Source Measure Unit. AD5520. FEATURES. GENERAL DESCRIPTION. Force/measure functions
Per Pin Parametric Measurement Unit/Source Measure Unit AD5520 FEATURES GENERAL DESCRIPTION Force/measure functions
The AD5520 is a single-channel, per pin parametric measure-
FIMV, FVMI, FVMV, FIMI, FNMV
ment unit (PPMU) for use in semiconductor automatic
Force/measure voltage range ±11 V
test equipment. The part is also suited for use as a source
4 user programmable force/measure current ranges
measurement unit for instrumentation applications. It
±4 μA, ±40 μA, ±400 μA, ±4 mA (external resistors)
contains programmable modes to force a pin voltage and
2 user programmable extended current ranges
measure the corresponding current, or force a current and
Up to 6 mA without external driver
measure the voltage. The AD5520 can force/measure over a
Higher currents with external driver
±11 V range or user-programmable currents up to ±4 mA
Clamp circuitry and window comparators on board
with its on-board force amplifier. An external amplifier is
Guard amplifier
required for wider current ranges. The device provides a force
64-lead LQFP package
sense capability to ensure accuracy at the tester pin. A guard
output is also available to drive the shield of a force/sense pair. The AD5520 is available in a 64-lead LQFP package.
Automatic test equipment Per pin PMU, shared pin PMU, device power supply instrumentation Source measure, parametric measurement, precision measurement FUNCTIONAL BLOCK DIAGRAM 0 1 2 AVEE AVCC IN IN IN P P P OUT0 OUT1 OUT2 P P P AD5520 COM COM COM COM COM COM FOH BW SELECT FOH3 FOH2 FIN FOH1 FOH0 MEASI5H CLAMP MEASI4H DETECT MEASI3H MEASI2H CLH MEASI1H CLL MEASI0H REFGND G = 16 MEASIOUT MEASIL ISENSE INST AMP GUARDIN MEASOUT VSENSE G = 1 INST AMP GUARD G = 1 MEASVH MEASVOUT COMPARATOR MEASVL CPH CPOH AGND LOGICS QM5 CPOL ECT QM4 CPL ET D B 2 1 0 L DD SEL SEL ST CPCK STANDBY MOE CPSEL F M AM AM AM CLHDETECT CL CS DV DGND AC0 AC1
03701-001 Figure 1.
Rev. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Tel: 781.329.4700 www.analog.com Devices. Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 © 2005 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS SPECIFICATIONS TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INTERFACE STANDBY MODE FORCE VOLTAGE OR FORCE CURRENT MEASURED PARAMETER CURRENT RANGES RS SELECTION FORCE CONTROL AMPLIFIER COMPARATOR FUNCTION AND STROBING CLAMP FUNCTION HIGH CURRENT RANGES CIRCUIT OPERATION FORCE VOLTAGE MEASURE CURRENT FORCE CURRENT MEASURE VOLTAGE SHORT CIRCUIT PROTECTION SETTLING TIME CONSIDERATIONS PCB LAYOUT AND POWER SUPPLY DECOUPLING TYPICAL CONNECTION CIRCUIT FOR THE AD5520 TYPICAL APPLICATION CIRCUIT EVALUATION BOARD FOR THE AD5520 OUTLINE DIMENSIONS ORDERING GUIDE
