Datasheet ISOSD61 (STMicroelectronics) - 7
Description16-bit isolated Sigma-Delta modulator, single-ended and LVDS interfaces
Pages / Page23 / 7 — ISOSD61. Device specifications. Parameter. Symbol. Min. Typ. Max. Units. …
File Format / SizePDF / 557 Kb
ISOSD61. Device specifications. Parameter. Symbol. Min. Typ. Max. Units. Test conditions. POWER SUPPLY. Table 8. Timing specifications. Symbo
ISOSD61 Device specifications Parameter Symbol Min Typ Max Units Test conditions POWER SUPPLY Table 8 Timing specifications Symbo
ISOSD61 Device specifications Parameter Symbol Min. Typ. Max. Units Test conditions
Signal-to-noise ratio SNR 86 dB Signal-to-(noise + distortion) ratio SNDR 80 dB Effective number of bits ENOB 13 bits Spurious free dynamic Range SFDR 83 dB Total harmonic distortion THD -83 dB Transient Pulse repetition frequency Common-mode transient immunity CMTI 25 30 kV/µs up to 100 KHz
POWER SUPPLY
35 mA @ 25 MHz VDDISO supply current IDDISO 30 mA @ 10 MHz VDD = 5 V, 13 mA fMCLKIN = 25 MHz VDD = 5 V, 11 mA fMCLKIN = 10 MHz VDD supply current IDD VDD = 3.3 V, 12.5 mA fMCLKIN = 25 MHz VDD = 3.3 V, 10.5 mA fMCLKIN = 10 MHz 1. Guaranteed by characterization
Table 8. Timing specifications Symbo Parameter Min. Typ. Max. Units Test conditions l
Modulator clock input frequency fCK 5 25 MHz Clock duty cycle 48% to 52% Data delay after rising edge of CK tD 5 20 ns CL = 15 pF
Figure 4. Timing sequence diagram
MCLK 1 2 3 4 MDAT t MCLK period D The data is provided to the MDAT output 2 clock cycles after the effective sampling instant.
DS13605
Rev 3 page 7/23
Document Outline Cover image Product status link / summary Features Application Description 1 Device overview 2 Pin description 3 Device specifications 4 Terminology 5 Theory of operation 6 Package description 7 Ordering information Revision history Contents List of tables List of figures
