Datasheet B2045G, B20200G (Thinki Semiconductor) - 2
Manufacturer | Thinki Semiconductor |
Description | 20.0 Ampere Surface Mount Dual Common Cathode Schottky Barrier Rectifiers |
Pages / Page | 2 / 2 — RATINGS AND CHARACTERISTICS CURVES |
File Format / Size | PDF / 1.3 Mb |
B2045G thru B20200G
(TA=25°C unless otherwise noted) 45V=B2045G 60V=B2060G 100V=B20100G 150V=B20150G 200V=B20200G FIG.1 FORWARD CURRENT DERATING CURVE FIG. 2 MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT PER LEG 25 ) (A 150 NT 20 125 8.3ms Single Half Sine Wave A D AR ) 15 CURRE 100 W (A R NT URGE 75 10 E FO AG 50 CURRE ARD S 5 RW AVER RESISTIVE OR 25 O INDUCTIVELOAD F 0 K A 0 50 60 70 80 90 100 110 120 130 140 150 E P 1 10 100 CASE TEMPERATURE (oC) NUMBER OF CYCLES AT 60 Hz FIG. 3 TYPICAL FORWARD CHARACTERISTICS FIG. 4 TYPICAL REVERSE CHARACTERISTICS PER LEG PER LEG 100 100 Pulse Width=300μs 45V 1% Duty Cycle 60V-200V A A 10 D 10 SE R T A J=125°C ) W R ) EVER A 1 T (A (m J=125°C TJ=25°C S R 1 S FO U NT NT U O EO E 0.1 TAN CURRE CURRE TJ=75°C TAN 0.1 45V STAN 0.01 STAN 60V IN IN 100V-200V TJ=25°C 0.01 0.001 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 0 20 40 60 80 100 120 140 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) FIG. 5 TYPICAL JUNCTION CAPACITANCE PER FIG. 6 TYPICAL TRANSIENT THERMAL IMPEDANCE LEG PER LEG 10000 f=1.0MHz 100 A Vsig=50mVp-p ) (pF L A ) CE M W N 10 A ER C/ IT 1000 (° C A T TH P NCE SIEN DA E 1 P ION CA AN 45V IM TR NCT 60V - 200V JU 100 0.1 0.1 1 10 100 0.01 0.1 1 10 100 REVERSE VOLTAGE (V) T-PULSE DURATION(s) Rev.10T Page 2/2 © 1995 Thinki Semiconductor Co., Ltd. http://www.thinkisemi.com.tw/
