Datasheet MAX6674 (Maxim) - 3
Manufacturer | Maxim |
Description | Cold-Junction-Compensated K-Thermocouple-to-Digital Converter (0°C to +128°C) |
Pages / Page | 8 / 3 — Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. … |
File Format / Size | PDF / 566 Kb |
Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. TIMING. Note 1:. Note 2:
MAX6674 Cold-Junction-Compensated K-Thermocouple- to-Digital Converter (0°C to +128°C)
(VCC = +3.0V to +5.5V, TA = -20°C to +85°C, unless otherwise noted. Typical values specified at +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
Output High Voltage VOH ISOURCE = 1.6mA VCC - 0.4 V Output Low Voltage VOL ISINK = 1.6mA 0.4 V
TIMING
Serial Clock Frequency fSCL 4.3 MHz SCK Pulse High Width tCH 100 ns SCK Pulse Low Width tCL 100 ns CSB Fall to SCK Rise tCSS CL = 10pF 100 ns CSB Fall to Output Enable tDV CL = 10pF 100 ns CSB Rise to Output Disable tTR CL = 10pF 100 ns SCK Fall to Output Data Valid tDO CL = 10pF 100 ns
Note 1:
All specifications are 100% tested at TA = +25°C. Specification limits over temperature (TA = -20°C to +85°C) are guaran- teed by design and characterization, not production tested.
Note 2:
Guaranteed by design. Not production tested.
Typical Operating Characteristics
(VCC = +3.3V, TA = +25°C, unless otherwise noted.)
OUTPUT CODE ERROR OUTPUT CODE ERROR vs. TEMPERATURE vs. VOLTAGE DIFFERENTIAL
2 2 MAX6674 toc01 MAX6674 toc02 °C) °C) 1 1 0 0 OUTPUT CODE ERROR ( -1 -1 OUTPUT CODE ERROR ( -2 -2 0 15 30 45 60 75 90 -1200 0 1200 2400 3600 4800 TEMPERATURE (°C) VOLTAGE DIFFERENTIAL (µV) www.maximintegrated.com Maxim Integrated │ 3
