Datasheet MM5120 (Menlo Micro)
ManufacturerMenlo Micro
Description12GHz High Power RF SP4T Switch
Pages / Page2 / 1 — PRO DUC T B R I E F. FE ATU R E S. APPLI CATI O N S. MAR K E TS
File Format / SizePDF / 467 Kb
Datasheet MM5120 Menlo Micro
PRO DUC T B R I E F
MM5120 12GHz High Power RF SP4T Switch The Menlo Micro MM5120 is the world’s first
FE ATU R E S
generally available high-power RF SP4T micro- • DC to 12 GHz Frequency Range • 25 W (CW), 150 W (Pulsed) Power mechanical switch. Menlo Micro has developed a Handling @ 6.0 GHz new fabrication process and applied it to DC and • Ultra-Low Insertion Loss, 0.35 dB wideband RF/microwave switch applications. This @ 6 GHz • IP3 > 85 dBm new innovative technology enables robust and • 25 dB Isolation @ 6 GHz highly reliable switches capable of greater than • Maximum Voltage (AC or DC): 25 W CW power handling at 6.0 GHz. • +/-150 V on RF Input • High Reliability, > 3.0 Billion Switch The MM5120 provides ultra-low insertion loss and Cycles superior linearity from 12 GHz down to DC, with • Integrated Gate Control and greater than 3 billion switching cycles guaranteed • High Voltage Generator at +85 °C. Integrated high voltage generation • 4.0 mm x 4.0 mm Lead-Free RoHS Compliant BGA Package simplifies usage when only a single low voltage is required for operation.
APPLI CATI O N S
• Switched Filter Banks and Tunable The MM5120 is an ideal solution for replacing Filters large RF electromechanical relays, as well as RF/ • High Power RF Front-Ends microwave solid-state switches where linearity • Low-Loss Switch Matrices and insertion loss are critical parameters. • RF EM Relay Replacement • Antenna Tuning • Antenna Beam Steering • Digital Step Attenuators
MAR K E TS
• Defense and Aerospace • Test and Measurement • Wireless Infrastructure
