Datasheet 74HC4060, 74HCT4060 (NXP) - 7
Manufacturer | NXP |
Description | 14-stage binary ripple counter with oscillator |
Pages / Page | 20 / 7 — Nexperia. 74HC4060; 74HCT4060. 14-stage binary ripple counter with … |
File Format / Size | PDF / 324 Kb |
Nexperia. 74HC4060; 74HCT4060. 14-stage binary ripple counter with oscillator. Symbol Parameter. Conditions. 25 °C. -40 °C to. Unit
link to page 7 link to page 7
Nexperia 74HC4060; 74HCT4060 14-stage binary ripple counter with oscillator Symbol Parameter Conditions 25 °C -40 °C to -40 °C to Unit +85 °C +125 °C Min Typ Max Min Max Min Max
II input leakage VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1.0 - ±1.0 μA current ICC supply VI = VCC or GND; IO = 0 A; - - 8.0 - 80 - 160 μA current VCC = 6.0 V CI input - 3.5 - - - - - pF capacitance
74HCT4060
VIH HIGH-level MR input; VCC = 4.5 V to 5.5 V [1] 2.0 - - 2.0 - 2.0 - V input voltage RS input; VCC = 4.5 V 3.6 - - 3.6 - 3.6 - V VIL LOW-level MR input; VCC = 4.5 V to 5.5 V [1] - - 0.8 - 0.8 - 0.8 V input voltage RS input; VCC = 4.5 V - - 0.9 - 0.9 - 0.9 V VOH HIGH-level RTC output; RS = MR = VCC output IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V voltage IO = -0.65 mA; VCC = 4.5 V 3.98 - - 3.84 - 3.7 - V RTC output; RS = MR = GND IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -2.6 mA; VCC = 4.5 V 3.98 - - 3.84 - 3.7 - V CTC output; RS = VIH; MR = VIL IO = -3.2 mA; VCC = 4.5 V 3.98 - - 3.84 - 3.7 - V VI = VIH or VIL; except RTC output IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V VI = VIH or VIL; except RTC and CTC outputs IO = -4.0 mA; VCC = 4.5 V 3.98 - - 3.84 - 3.7 - V VOL LOW-level RTC output; RS = VCC; MR = GND output IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V voltage IO = 2.6 mA; VCC = 4.5 V - - 0.26 - 0.33 - 0.4 V CTC output; RS = VIL; MR = VIH IO = 3.2 mA; VCC = 4.5 V - - 0.26 - 0.33 - 0.4 V VI = VIH or VIL; except RTC output IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V VI = VIH or VIL; except RTC and CTC outputs IO = 4.0 mA; VCC = 4.5 V - - 0.26 - 0.33 - 0.4 V II input leakage VI = VCC or GND; VCC = 5.5 V - - ±0.1 - ±1.0 - ±1.0 μA current ICC supply VI = VCC or GND; VCC = 5.5 V; - - 8.0 - 80 - 160 μA current IO = 0 A ΔICC additional per input pin; VI = VCC - 2.1 V; - 40 144 - 180 - 196 μA supply other inputs at VCC or GND; current VCC = 4.5 V to 5.5 V; IO = 0 A CI input - 3.5 - - - - - pF capacitance [1] For HCT4060, only input MR (pin 12) has TTL input switching levels. 74HC_HCT4060 All information provided in this document is subject to legal disclaimers. © Nexperia B.V. 2020. Al rights reserved
Product data sheet Rev. 5 — 8 May 2020 7 / 20
Document Outline 1. General description 2. Features and benefits 3. Applications 4. Ordering information 5. Functional diagram 6. Pinning information 6.1. Pinning 6.2. Pin description 7. Functional description 8. Limiting values 9. Recommended operating conditions 10. Static characteristics 11. Dynamic characteristics 11.1. Waveforms and test circuit 12. RC oscillator 12.1. Timing component limitations 12.2. Typical crystal oscillator circuit 13. Package outline 14. Abbreviations 15. Revision history 16. Legal information Contents
