Datasheet VCNL36825T (Vishay) - 2
ManufacturerVishay
DescriptionProximity Sensor With Interrupt, VCSEL, and I2C Interface
Pages / Page16 / 2 — VCNL36825T. ORDERING INFORMATION ORDERING CODE. PACKAGING. VOLUME (1). …
File Format / SizePDF / 238 Kb
VCNL36825T. ORDERING INFORMATION ORDERING CODE. PACKAGING. VOLUME (1). REMARKS. Note. ABSOLUTE MAXIMUM RATINGS. PARAMETER
VCNL36825T ORDERING INFORMATION ORDERING CODE PACKAGING VOLUME (1) REMARKS Note ABSOLUTE MAXIMUM RATINGS PARAMETER
VCNL36825T
VCNL36825T Tape and reel MOQ: 4500 pcs, 4500 pcs/reel 2.0 mm x 1.25 mm x 0.5 mm
Note
(1) MOQ: minimum order quantity
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. MAX. UNIT
Supply voltage VDD -0.3 3.8 V Operation temperature range Tamb -40 +85 °C Storage temperature range Tstg -40 +100 °C
BASIC CHARACTERISTICS
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Supply voltage (1) VDD 2.64 - 3.6 V Supply current Excluding VCSEL driving IDD 100 200 300 μA Light condition = dark; Shutdown current I V DD (SD) - 1 - μA DD = 3.3 V, Tamb = 25 °C I2C supply voltage VPULL UP 1.65 - - V I2C signal input, logic high VDD = 3.3 V VIH 1.26 - - V I2C signal input, logic low VDD = 3.3 V VIL - - 0.73 V Peak wavelength of VCSEL IF = 12 mA λp(VCSEL) - 940 - nm PS view angle horizontal - ± 45 - ° PS view angle vertical - ± 60 - °
Note
(1) Based on VCSEL current setting, VDD min. voltage need adjust, example as below VCSEL current setting 10 mA 12 mA 14 mA 16 mA 18 mA 20 mA Min. VDD 2.64 V 2.70 V 2.76 V 2.81 V 2.85 V 2.90 V Rev. 1.2, 22-Mar-2021
2
Document Number: 80235 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
