Datasheet UPS120, UPS130, UPS140 (MCC) - 3
ManufacturerMCC
Description1 Amp Schottky Rectifier 20 to 40 Volts
Pages / Page3 / 3 — UPS120. thru. UPS140. M. C. C. Figure. 4. Peak. Forward. Surge. Current. …
File Format / SizePDF / 101 Kb
UPS120. thru. UPS140. M. C. C. Figure. 4. Peak. Forward. Surge. Current. 50. 40. 30. 20. Amps. 10. 5. 0. 1. 2. 4. 6. 8. 10. 20. 40. 60. 80. 100. Cycles. Peak. Forward. Surge. Current. -
UPS120 thru UPS140 M C C Figure 4 Peak Forward Surge Current 50 40 30 20 Amps 10 5 0 1 2 4 6 8 10 20 40 60 80 100 Cycles Peak Forward Surge Current -
UPS120 thru UPS140 M C C Figure 4 Peak Forward Surge Current 50 40 30 20 Amps 10 5 0 1 2 4 6 8 10 20 40 60 80 100 Cycles Peak Forward Surge Current - Amperes versus Number Of Cycles At 60Hz - Cycles Figure 6 Reverse Recovery Time Characteristic And Test Circuit Diagram 50Ω 10Ω trr +0.5A 0 Pulse -0.25 25Vdc Generator Note 2 1Ω Oscilloscope -1.0 Note 1 1cm Notes: Set Time Base for 20/100ns/cm 1. Rise Time = 7ns max. Input impedance = 1 megohm, 22pF 2. Rise Time = 10ns max. Source impedance = 50 ohms 3. Resistors are non-inductive www.mccsemi.com
