Datasheet SD101AW, SD101BW, SD101CW (Vishay)
ManufacturerVishay
DescriptionSmall Signal Schottky Diodes
Pages / Page4 / 1 — SD101AW, SD101BW, SD101CW. Small Signal Schottky Diodes. FEATRUES. DESIGN …
File Format / SizePDF / 93 Kb
SD101AW, SD101BW, SD101CW. Small Signal Schottky Diodes. FEATRUES. DESIGN SUPPORT TOOLS. MECHANICAL DATA. Case:. Weight:
Datasheet SD101AW, SD101BW, SD101CW Vishay
Small Signal Schottky Diodes FEATRUES
• For general purpose applications • The low forward voltage drop and fast switching make it ideal for protection of MOS devices, steering, biasing and coupling diodes for fast switching and low logic level applications • The SD101 series is a metal-on-silicon Schottky barrier device which is protected by a
click logo to get started PN junction guardring • AEC-Q101 qualified available Models Available • Base P/N-E3 - RoHS-compliant, commercial grade • Base P/N-HE3 - RoHS-compliant, AEC-Q101 qualified
MECHANICAL DATA
• Material categorization: for definitions of compliance
Case:
SOD-123 please see www.vishay.com/doc?99912
Weight:
approx. 10.3 mg 
Packaging codes/options:
 18/10K per 13" reel (8 mm tape), 10K/box   08/3K per 7" reel (8 mm tape), 15K/box
PARTS TABLE CIRCUIT PART ORDERING CODE TYPE MARKING REMARKS CONFIGURATION
SD101AW-E3-08 or SD101AW-E3-18 SD101AW Single SA SD101AW-HE3-08 or SD101AW-HE3-18 SD101BW-E3-08 or SD101BW-E3-18 SD101BW Single SB Tape and reel SD101BW-HE3-08 or SD101BW-HE3-18 SD101CW-E3-08 or SD101CW-E3-18 SD101CW Single SC SD101CW-HE3-08 or SD101CW-HE3-18
ABSOLUTE MAXIMUM RATINGS
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION PART SYMBOL VALUE UNIT
SD101AW VRRM 60 V Repetitive peak reverse voltage SD101BW VRRM 50 V SD101CW VRRM 40 V Power dissipation (infinite heatsink) (1) Ptot 400 mW Forward continuous current IF 30 mA Maximum single cycle surge 10 μs square wave IFSM 2 A
Note
(1) Valid provided that electrodes are kept at ambient temperature
THERMAL CHARACTERISTICS
PARAMETER TEST CONDITION SYMBOL VALUE UNIT
Thermal resistance junction to ambient air (1) RthJA 300 K/W Junction temperature (1) Tj 125 °C Storage temperature range Tstg -65 to +150 °C Operating temperature range Top -55 to +125 °C
Note
(1) Valid provided that electrodes are kept at ambient temperature Rev. 1.9, 23-Feb-18
1
Document Number: 85679 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
