Datasheet ADN4624 (Analog Devices) - 10
Description5.7 kV RMS, Quad-Channel LVDS 2.5 Gigabit Isolator
Pages / Page20 / 10 — ADN4624. TYPICAL PERFORMANCE CHARACTERISTICS. Figure 4. Supply Current …
File Format / SizePDF / 3.5 Mb
ADN4624. TYPICAL PERFORMANCE CHARACTERISTICS. Figure 4. Supply Current vs. Input Clock Frequency
ADN4624 TYPICAL PERFORMANCE CHARACTERISTICS Figure 4 Supply Current vs Input Clock Frequency
Data Sheet
VDD1 = VDD2 = 1.8 V, TA = 25°C, REFRESH1 = GND1, REFRESH2 = GND2, RL = 100 Ω, 1.25 GHz clock input with |VID| = 200 mV, VIC = 1.2 V, and tR and tF < 0.05 ns, unless otherwise noted.
Figure 4. Supply Current vs. Input Clock Frequency Figure 7. Differential Output Voltage, |VOD| vs. Supply Voltage, VDD1 and VDD2 Figure 5. Supply Current vs. Input Data Rate, 223 − 1 PRBS Figure 8. Differential Output Voltage, |VOD| vs. Ambient Temperature Figure 6. Supply Current vs. Ambient Temperature Figure 9. Differential Output Voltage, |VOD| vs. Input Clock Frequency analog.com Rev. 0 | 10 of 20
Document Outline Features Applications Functional Block Diagram General Description Specifications Receiver Input Threshold Test Voltages Timing Specifications Insulation and Safety Related Specifications Package Characteristics Regulatory Information DIN V VDE V 0884-11 (VDE V 0884-11) Insulation Characteristics (Pending) Recommended Operating Conditions Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADN4624 ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits and Switching Characteristics Theory of Operation Isolation and Refresh Truth Table Applications Information PCB Layout Application Examples Magnetic Field Immunity Insulation Lifetime Surface Tracking Insulation Wear Out Calculation and Use of Parameters Example Outline Dimensions Ordering Guide Evaluation Boards
