Applications Information Introduction —0.026Product Selection Avago’s family of Schottky products provides unique solutions to many design problems. 0.079 The first step in choosing the right product is to select the 0.039 diode type. All of the products in the HSMS-280x family use the same diode chip, and the same is true of the 0.022 HSMS-281x and HSMS-282x families. Each family has a dif- ferent set of characteristics which can be compared most Dimensions in inches easily by consulting the SPICE parameters in Table 1. Figure 6. Recommended PCB Pad Layout for Avago’s SC70 3L/SOT-323 A review of these data shows that the HSMS-280x family Products. has the highest breakdown voltage, but at the expense of Assembly Instructions a high value of series resistance (Rs). In applications which do not require high voltage the HSMS-282x family, with a SOT-363 PCB Footprint lower value of series resistance, will offer higher current carrying capacity and better performance. The HSMS-281x A recommended PCB pad layout for the miniature SOT- family is a hybrid Schottky (as is the HSMS-280x), offering 363 (SC-70, 6 lead) package is shown in Figure 7 (dimen- lower 1/f or flicker noise than the HSMS-282x family. sions are in inches). This layout provides ample allowance for package placement by automated assembly equip- In general, the HSMS-282x family should be the designer’s ment without adding parasitics that could impair the first choice, with the -280x family reserved for high voltage performance. applications and the HSMS-281x family for low flicker noise applications. 0.026Assembly InstructionsSOT-323 PCB Footprint A recommended PCB pad layout for the miniature SOT- 0.079 323 (SC-70) package is shown in Figure 6 (dimensions are in inches). This layout provides ample allowance for 0.039 package placement by automated assembly equipment without adding parasitics that could impair the perfor- mance. 0.018Dimensions in inchesFigure 7. Recommended PCB Pad Layout for Avago’s SC70 6L/SOT-363 Products.Table 1. Typical SPICE ParametersParameterUnitsHSMS-280xHSMS-281xHSMS-282x BV V 75 25 15 CJ0 pF 1.6 1.1 0.7 EG eV 0.69 0.69 0.69 IBV A 1 E-5 1 E-5 1 E-4 IS A 3 E-8 4.8 E-9 2.2 E-8 N 1.08 1.08 1.08 RS Ω 30 10 6 PB (VJ) V 0.65 0.65 0.65 PT (XTI) 2 2 2 M 0.5 0.5 0.5 5
