Datasheet 1EDBx275F (Infineon) - 4
Manufacturer | Infineon |
Description | Single-channel isolated gate-driver IC in 150 mil DSO-8 package |
Pages / Page | 32 / 4 — EiceDRIVER™ 1EDBx275F Single-channel isolated gate-driver ICs in 150 mil … |
Revision | 02_01 |
File Format / Size | PDF / 975 Kb |
EiceDRIVER™ 1EDBx275F Single-channel isolated gate-driver ICs in 150 mil DSO package Pin configuration and description
link to page 29 link to page 29
EiceDRIVER™ 1EDBx275F Single-channel isolated gate-driver ICs in 150 mil DSO package Pin configuration and description 1 Pin configuration and description
VDDI 1 8 GNDO IN+ 2 7 OUT_SNK 1EDBx275F IN- 3 6 OUT_SRC GNDI 4 5 VDDO
Figure 2 Pin configuration (top side view) Table 2 Pin description Pin Symbol Description
1 VDDI Input-side supply voltage (3 V to 15 V) 2 IN+ Non-inverting driver input (active high); if IN+ is low or left open, OUT_SNK is low 3 IN- Inverting driver input (active low); if IN- is high or left open, OUT_SNK is low 4 GNDI Input-side ground reference 5 VDDO Output-side supply voltage (up to 20 V) 6 OUT_SRC Driver output source, low-impedance switch to VDDO 7 OUT_SNK Driver output sink, low-impedance switch to GNDO 8 GNDO Output-side ground reference For package drawing details see
Chapter 8 Package outline dimensions
. Final Data Sheet 4 Rev. 2.1 2021-04-21 Document Outline Description Table of Contents 1 Pin configuration and description 2 Functional description 2.1 Block diagram 2.2 Power supply and Undervoltage Lockout (UVLO) 2.2.1 Input supply voltage 2.2.2 Output supply voltage 2.2.3 Input stage 2.3 Driver output 2.4 Output active clamping 2.5 CT communication and input to output data transmission 3 Electrical characteristics and parameters 3.1 Absolute maximum ratings 3.2 Thermal characteristics 3.3 Operating range 3.4 Electrical characteristics 3.5 Isolation specifications 4 Timing diagrams 5 Layout recommendation 6 Application notes 6.1 Driving 600 V CoolGaNTM 6.2 Driving 650 V CoolSiCTM 7 Typical characteristics 8 Package outline dimensions 8.1 Device numbers and markings 8.2 Package PG-DSO-8 Revision history
