Datasheet 74AHCU04 (Nexperia) - 4
ManufacturerNexperia
DescriptionHex unbuffered inverter
Pages / Page14 / 4 — Nexperia. 74AHCU04. Hex unbuffered inverter. 9. Static characteristics …
Revision18052020
File Format / SizePDF / 247 Kb
Nexperia. 74AHCU04. Hex unbuffered inverter. 9. Static characteristics Table 6. Static characteristics. Symbol Parameter
Nexperia 74AHCU04 Hex unbuffered inverter 9 Static characteristics Table 6 Static characteristics Symbol Parameter
Nexperia 74AHCU04 Hex unbuffered inverter 9. Static characteristics Table 6. Static characteristics
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter Conditions 25 °C -40 °C to -40 °C to Unit +85 °C +125 °C Min Typ Max Min Max Min Max
VIH HIGH-level VCC = 2.0 V 1.7 - - 1.7 - 1.7 - V input voltage VCC = 3.0 V 2.4 - - 2.4 - 2.4 - V VCC = 5.5 V 4.4 - - 4.4 - 4.4 - V VIL LOW-level VCC = 2.0 V - - 0.3 - 0.3 - 0.3 V input voltage VCC = 3.0 V - - 0.6 - 0.6 - 0.6 V VCC = 5.5 V - - 1.1 - 1.1 - 1.1 V VOH HIGH-level VI = VIH or VIL output voltage IO = -50 μA; VCC = 2.0 V 1.8 2.0 - 1.8 - 1.8 - V IO = -50 μA; VCC = 3.0 V 2.7 3.0 - 2.7 - 2.7 - V IO = -50 μA; VCC = 4.5 V 4.0 4.5 - 4.0 - 4.0 - V IO = -4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.4 - V IO = -8.0 mA; VCC = 4.5 V 3.94 - - 3.8 - 3.7 - V VOL LOW-level VI = VIH or VIL output voltage IO = 50 μA; VCC = 2.0 V - 0 0.2 - 0.2 - 0.2 V IO = 50 μA; VCC = 3.0 V - 0 0.3 - 0.3 - 0.3 V IO = 50 μA; VCC = 4.5 V - 0 0.5 - 0.5 - 0.5 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V II input leakage VI = 5.5 V or GND; - - 0.1 - 1.0 - 2.0 μA current VCC = 0 V to 5.5 V ICC supply current VI = VCC or GND; IO = 0 A; - - 2.0 - 20 - 40 μA VCC = 5.5 V CI input - 3 10 - 10 - 10 pF capacitance 74AHCU04 All information provided in this document is subject to legal disclaimers. © Nexperia B.V. 2020. Al rights reserved
Product data sheet Rev. 5 — 18 May 2020 4 / 14
Document Outline 1. General description 2. Features and benefits 3. Ordering information 4. Functional diagram 5. Pinning information 5.1. Pinning 5.2. Pin description 6. Functional description 7. Limiting values 8. Recommended operating conditions 9. Static characteristics 10. Dynamic characteristics 10.1. Waveforms 11. Typical transfer characteristics 12. Application information 13. Package outline 14. Abbreviations 15. Revision history 16. Legal information Contents
