Datasheet 74HCU04 (Nexperia) - 9
Manufacturer | Nexperia |
Description | Hex unbuffered inverter |
Pages / Page | 14 / 9 — Nexperia. 74HCU04. Hex unbuffered inverter. 13. Package outline |
Revision | 31052021 |
File Format / Size | PDF / 259 Kb |
Nexperia 74HCU04 Hex unbuffered inverter 13. Package outline SO14: plastic smal outline package; 14 leads; body width 3.9 mm SOT108-1
D E A X c y H E v M A Z 14 8 Q A 2 (A 3) A A 1 pin 1 index θ L p L 1 7 e w M detail X b p 0 2.5 5 mm scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A 1 A 2 A 3 b p c D (1) E (1) (1) e H E L L p Q v w y Z
θ mm 1.75 0.25 1.45 0.25 8.75 4.0 1.0 0.7 0.7 0.10 1.25 0.25 0.49 0.36 0.19 8.55 3.8 1.27 6.2 5.8 1.05 0.4 0.6 0.25 0.25 0.1 0.3 8 o 0.057 0.0100 0.35 0.16 0.244 0.039 0.028 0.028 0 o inches 0.069 0.010 0.004 0.049 0.01 0.019 0.014 0.0075 0.34 0.15 0.05 0.041 0.228 0.016 0.024 0.01 0.01 0.004 0.012
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES OUTLINE EUROPEAN VERSION PROJECTION ISSUE DATE IEC JEDEC JEITA
SOT108-1 076E06 MS-012 99-12-27 03-02-19
Fig. 17. Package outline SOT108-1 (SO14)
74HCU04 All information provided in this document is subject to legal disclaimers. © Nexperia B.V. 2021. Al rights reserved
Product data sheet Rev. 9 — 31 May 2021 9 / 14
Document Outline 1. General description 2. Features and benefits 3. Ordering information 4. Functional diagram 5. Pinning information 5.1. Pinning 5.2. Pin description 6. Functional description 7. Limiting values 8. Recommended operating conditions 9. Static characteristics 10. Dynamic characteristics 10.1. Waveform and test circuit 11. Typical transfer characteristics 12. Application information 13. Package outline 14. Abbreviations 15. Revision history 16. Legal information Contents
