LTC3337 ABSOLUTE MAXIMUM RATINGSPIN CONFIGURATION(Note 1) TOP VIEW BAT_IN, BAT_OUT, AVCC Voltage .. –0.3V to 6V (BAT_OUT – BAT_IN) Differential Voltage ..0.3V DVCC, SCL, SDA Voltage .. –0.3V to 6V BAT_OUT BAT_IN IPK[2:0] Voltage .. .. .. . ... .. . ... –0.3V to [Lesser of BAL 1 12 11 10 IPK0 (BAT_IN + 0.3V) or 6V] AVCC 2 9 IPK1 13 BAL Voltage ..–0.3V to [Lesser of GND DV 3 8 IPK2 (BAT_OUT + 0.3V) or 6V] CC IRQ, BATOUT_OK Current .. ±1mA SCL 4 7 BATOUT_OK 5 6 BAT_OUT Current ..150mA SDA IRQ SDA Current ...5mA LFCSP PACKAGE Operating Junction Temperature 12-LEAD (2mm × 2mm × 0.75mm) PLASTIC QFN Range (Notes 2, 3) ... –40°C to 125°C TJMAX = 125°C, θJA = 52.78°C/W EXPOSED PAD (PIN 13) IS GND, MUST BE SOLDERED TO PCB Storage Temperature Range .. –65°C to 150°C ORDER INFORMATIONPART MARKINGMSLTAPE AND REELTAPE AND REEL (MINI) DEVICE FINISH CODE PACKAGE DESCRIPTIONRATING TEMPERATURE RANGE LTC3337ERC#TRPBF LTC3337ERC#TRMPBF LHMM e4 12-Lead (2mm × 2mm × 0.75mm) LFCSP MSL1 –40°C to 125°C Contact the factory for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Tape and reel specifications. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. Rev. 0 2 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics Timing Diagram Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Typical Applications Related Parts
