Datasheet MAX38889 (Maxim)
ManufacturerMaxim
Description2.5V–5.5V, 3A Reversible Buck/Boost Regulator for Backup Applications
Pages / Page17 / 1 — here. MAX38889. 2.5V to 5.5V, 3A Reversible Buck/Boost. Regulator for …
File Format / SizePDF / 588 Kb
here. MAX38889. 2.5V to 5.5V, 3A Reversible Buck/Boost. Regulator for Backup Applications. Product Highlights
Datasheet MAX38889 Maxim
link to page 16 Click
here
for production status of specific part numbers.
MAX38889 2.5V to 5.5V, 3A Reversible Buck/Boost Regulator for Backup Applications Product Highlights Simplified Application Diagram
• 2.5V to 5.5V System Output Voltage Range • 0.5V to 5.5V Supercapacitor Voltage Range CHARGE DISCHARGE • ±1% Threshold Accuracy L1 • 2.5% Hysteresis between Backup and Charging 0.47µH VCAP VSYS • 1A to 3A Peak Inductor Current Limit 2.7V (MAX) 3.0V (BACKUP) LX CAP SYS CSC 10F • Peak Inductor Current Is Pin-Programmable C1 R1 R6 R8 R9 C5 SUPER MAIN SYSTEM 22µF 1.82MΩ 1.82MΩ 1MΩ 1MΩ 150µF BATTERY CAP LOAD (REMOVABLE) over 1A to 3A through External Resistor FBCR FBS
MAX38889
R2 • 402kΩ 94% Peak Efficiency, Charging or Discharging Mode BKB BACKUP FBCH RDY READY • CHARGE ENABLE ENC 4µA Quiescent Current in Ready State ENB ISET GND PGND • After Supercapacitor Is Charged, Draws only BACKUP ENABLE R3 RISET R7 33kΩ 1.21MΩ 499kΩ 4µA of Quiescent Current • Ready and Backup State Outputs • RDY and BKB Flags Provide Real-Time Status to System • 3mm x 3mm, 16-Pin TQFN Package
Pin Configuration Key Applications
ISET FBS FBCH FBCR 12 11 10 9 • Handheld Industrial Equipment • Portable Devices/Computers with Removable Battery SYS 13 8 LX • Industrial Sensor and Actuators • Aftermarket Automotive Tracking SYS 14 7 LX GND (EXPOSED PAD) PGND 15 6 LX PGND 16 5 CAP 1 2 3 4 ENC ENB RDY BKB
3mm x 3mm, 16 TQFN Ordering Information appears at end of data sheet.
19-101019; Rev 1; 5/21 Document Outline Product Highlights Key Applications Simplified Application Diagram Pin Configuration Absolute Maximum Ratings Package Information Electrical Characteristics Typical Operating Characteristics Pin Configuration Pin Descriptions Functional Diagram Detailed Description Application Circuits Supercapacitor Voltage Configuration System Voltage Configuration Charge/Discharge Current Configuration Charging Backup Applications Information Capacitor Selection Supercapacitor Selection Inductor Selection Status Flags BKB Flag RDY Flag Enabling the Device Charger Enable Input (ENC) Backup Enable Input (ENB) PCB Layout Guidelines Ordering Information
