Datasheet AEM30330 (E-peas) - 9
Manufacturer | E-peas |
Description | Highly Versatile, Regulated Single-Output, Buck-Boost Ambient Energy Manager for Vibration Sources with Optional Primary Battery |
Pages / Page | 33 / 9 — DATASHEET. AEM30330. 4. Typical Electrical Characteristics at 25 °C. … |
File Format / Size | PDF / 3.9 Mb |
DATASHEET. AEM30330. 4. Typical Electrical Characteristics at 25 °C. Symbol. Parameter. Conditions. Min. Typ. Max. Unit
link to page 18
DATASHEET AEM30330 4. Typical Electrical Characteristics at 25 °C Symbol Parameter Conditions Min Typ Max Unit
Power Conversion V P Source power required for cold STO > Vchrdy 3 µW SRC,CS start VSTO < Vchrdy 6 µW During cold start 0.275 4.5 V V Input voltage of the energy SRC source After cold start 0.1 4.5 V RZMPP MPPT ratio see Table 11 35, 50, 60, 65, 70, 75 or 80, depending on R_MPP[2:0] configuration % Timing T 200% of MPP,EVAL Duration of a MPP evaluation 50% of Table 8 Table 8 ms T 200% of MPP,PERIOD Time between two MPP evaluations 50% of Table 8 Table 8 s Storage element Maximum voltage accepted on VOVCH the storage element before V disabling its charging Minimum voltage required on the VCHRDY storage element before asserting see Table 9 Depends on STO_CFG[3:0] configuration V the ST_STO Minimum voltage accepted on VOVDIS the storage element before V entering into SHUTDOWN STATE Load Output Voltage VLOAD = 1.8V VSTO > 1.6V 60 HP_EN = 1 VLOAD = 2.5V ILOAD,MAX LOAD current drive capability VSTO > 1.6V 60 mA HP_EN = 1 VLOAD = 3.3V VSTO > 1.8V 60 HP_EN = 1 VLOAD Output voltage see Table 10 Depends on LOAD_CFG[2:0] configuration V Internal supply & Quiescent Current VVINT Internal voltage supply 2.2 V VSTO = 3.7V I VLOAD = 2.5V Q Quiescent current on STO EN_SLEEP = 0 875 nA HP_EN = 0 Symbol Logic Level Low High Logic output pins ST_STO Logic output levels on the status STO pins GND VSTO ST_LOAD Logic output levels on the status LOAD pins GND VLOAD ST_STO_RDY Logic output levels on the status STO_READY pins GND VLOAD ST_STO_OVDIS Logic output levels on the status STO_OVDIS pins GND VLOAD Table 6: Typical Electrical Characteristics DS_AEM30330_Rev1.0 Copyright © 2021 e-peas SA 9 Document Outline 1. Introduction 2. Absolute Maximum Ratings 3. Thermal Resistance 4. Typical Electrical Characteristics at 25 °C 5. Recommended Operation Conditions 6. Functional Block Diagram 7. Theory of Operation 7.1. DCDC Converter 7.2. Reset, Wake Up and Start States 7.2.1. Storage Element Priority Supercapacitor as a Storage Element Battery as a Storage Element 7.2.2. Load Priority 7.3. Supply State 7.4. Shutdown State 7.5. Sleep State 7.6. Primary Battery State 7.7. Maximum Power Point Tracking 7.8. Balancing for Dual-Cell Supercapacitor 8. System Configuration 8.1. High Power / Low Power Mode 8.2. Storage Element Configuration 8.3. Load Configuration 8.4. Custom Mode Configuration 8.5. Disable Storage Element Charging 8.6. MPPT Configuration 8.7. ZMPP Configuration 8.8. Source to Storage Element Feed- Through 8.9. Primary Battery Configuration 8.10. External Components 8.10.1. Storage element information 8.10.2. External inductor information 8.10.3. External capacitors information CSRC CINT CLOAD 9. Typical Application Circuits 9.1. Example Circuit 1 9.2. Example Circuit 2 9.3. Circuit Behaviour 10. Performance Data 10.1. DCDC Conversion Efficiency From SRC to STO in Low Power Mode 10.2. DCDC Conversion Efficiency From SRC to STO in High Power Mode 10.3. DCDC Conversion Efficiency From STO to LOAD in Low Power Mode 10.4. DCDC Conversion Efficiency From STO to LOAD in High Power Mode 10.5. Quiescent Current 11. Schematic 12. Layout 13. Package Information 13.1. Plastic Quad Flatpack No-Lead (QFN 40-pin 5x5mm) 13.2. Board Layout 14. Revision History
