Datasheet T24 (Vishay) - 3
ManufacturerVishay
DescriptionWet Tantalum SMD HI-TMP Capacitors for +200 °C Operation, Tantalum Metal Case With Glass-to-Tantalum Hermetic Seal
Pages / Page7 / 3 — T24. TAPE AND REEL PACKAGING. Notes. CARRIER TAPE DIMENSIONS. TAPE WIDTH. …
File Format / SizePDF / 126 Kb
T24. TAPE AND REEL PACKAGING. Notes. CARRIER TAPE DIMENSIONS. TAPE WIDTH. E2 MIN
T24 TAPE AND REEL PACKAGING Notes CARRIER TAPE DIMENSIONS TAPE WIDTH E2 MIN
T24
www.vishay.com Vishay
in inches [millimeters] 0.157 ± 0.004 T 10 pitches cumulative 2 [4.0 ± 0.10] (max.) tolerance on tape Deformation ± 0.008 [0.200] 0.059 + 0.004 - 0.0 between [1.5 + 0.10 - 0.0] Embossment 0.024 embossments 0.079 ± 0.002 0.069 ± 0.004 [0.600] [2.0 ± 0.05] [1.75 ± 0.10] max. Top cover A0 0.030 [0.75] tape 20° min. (3) F W K B (max.) (6) 0 Maximum 1 B0 component Top 0.030 [0.75] rotation cover min. (4) (Side or front sectional view) tape Center lines P1 For tape feeder 0.004 [0.10] of cavity D (min.) for components 1 reference only max. 0.079 x 0.047 [2.0 x 1.2] and larger (5) . USER DIRECTION including draft. Maximum OF FEED Concentric around B (1) 0 cavity size Cathode (-) R minimum: Anode (+) R 16 mm = 1.181" (30 mm) min. DIRECTION OF FEED Bending radius (2) 3.937 [100.0] 20° maximum component rotation 0.039 [1.0] max. Typical component Tape cavity 0.039 [1.0] B0 center line max. 0.9843 [250.0] Typical Camber component (Top view) A0 center line Allowable camber to be 0.039/3.937 [1/100] (Top view) Non-cumulative over 9.843 [250.0]
Notes
• Metric dimensions will govern. Dimensions in inches are rounded and for reference only. (1) A0, B0, K0, are determined by the maximum dimensions to the ends of the terminals extending from the component body and / or the body dimensions of the component. The clearance between the ends of the terminals or body of the component to the sides and depth of the cavity (A0, B0, K0) must be within 0.002" (0.05 mm) minimum and 0.020" (0.50 mm) maximum. The clearance allowed must also prevent rotation of the component within the cavity of not more than 20°. (2) Tape with components shall pass around radius “R” without damage. The minimum trailer length may require additional length to provide “R” minimum for 12 mm embossed tape for reels with hub diameters approaching N minimum. (3) This dimension is the flat area from the edge of the sprocket hole to either outward deformation of the carrier tape between the embossed cavities or to the edge of the cavity whichever is less. (4) This dimension is the flat area from the edge of the carrier tape opposite the sprocket holes to either the outward deformation of the carrier tape between the embossed cavity or to the edge of the cavity whichever is less. (5) The embossed hole location shall be measured from the sprocket hole controlling the location of the embossment. Dimensions of embossment location shall be applied independent of each other. (6) B1 dimension is a reference dimension tape feeder clearance only.
TAPE WIDTH W P2 F E1 E2 MIN.
0.630 + 0.012 / - 0.004 0.079 ± 0.004 0.295 ± 0.004 0.069 ± 0.004 0.561 16 mm [16.0 + 0.3 / - 0.1] [2.0 ± 0.1] [7.5 ± 0.1] [1.75 ± 0.1] [14.25] Revision: 21-Jan-2021
3
Document Number: 40261 For technical questions, contact: tantalum@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
