Datasheet MAX4571, MAX4572, MAX4573, MAX4574 (Maxim) - 4
ManufacturerMaxim
DescriptionSerially Controlled, Clickless Audio/Video Switches
Pages / Page16 / 4 — Serially Controlled, Clickless Audio/Video Switches. ELECTRICAL …
File Format / SizePDF / 322 Kb
Serially Controlled, Clickless Audio/Video Switches. ELECTRICAL CHARACTERISTICS—Single +3V Supply (continued). PARAMETER
Serially Controlled, Clickless Audio/Video Switches ELECTRICAL CHARACTERISTICS—Single +3V Supply (continued) PARAMETER
(V+ = +3V ±10%, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 2)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
ICOM_ = 4mA; TA = +25°C 4 10 On-Resistance R V+ = 2.7V; Ω Flatness (Note 5) FLAT VNO_ _ = 1V, 5V, 2V TA = TMIN to TMAX 10 VNO_ _ = 3V, 0.5V; TA = +25°C -0.2 0.01 0.2 NO_ _Off-Leakage I V nA Current (Notes 6 and 10) NO_ _ (OFF) COM_ = 0.5V, 3V; V+ = 3.6V TA = TMIN to TMAX -10 10 VNO_ _ = 3V, 0.5V; TA = +25°C -0.2 0.01 0.2 COM_ Off-Leakage I V nA Current (Notes 6 and 10) COM_ (OFF) COM_ = 0.5V, 3V; V+ = 3.6V TA = TMIN to TMAX -10 10 VCOM_ = 3V, 0.5V; TA = +25°C -0.2 0.01 0.2 COM _ On-Leakage V I NO_ _ = 3V, 0.5V, nA Current (Notes 6 and 10) COM_ (ON) or floating;
MAX4571–MAX4574
TA = TMIN to TMAX -10 10 V+ = 3.6V
AUDIO PERFORMANCE
Total Harmonic Distortion f THD+N IN = 1kHz, RL = 600Ω, VNO_ = 0.5VRMS, 0.07 % plus Noise VNO_ _ = 1.5V V Off-Isolation (Note 7) V NO_ _ = 0.5VRMS, fIN = 20kHz, RL = 600Ω, ISO(A) -90 dB Figure 1 V Channel-to-Channel Crosstalk V NO_ _ = 0.5VRMS, fIN = 20kHz, RS = 600Ω, CT(A) -90 dB Figure 1
VIDEO PERFORMANCE
V Off-Isolation (Note 7) V NO_ _ = 0.5VRMS, fIN = 10MHz, RL = 50Ω, ISO(V) -50 dB Figure 1 V Channel-to-Channel Crosstalk V NO_ _ = 0.5VRMS, fIN = 10MHz, RS = 50Ω, CT(V) -52 dB Figure 1 -3dB Bandwidth BW RSOURCE = 50Ω, RL = 50Ω, CL = 35pF >150 MHz Off Capacitance COFF(NO) fIN = 1MHz 9 pF
DYNAMIC TIMING WITH CLICKLESS MODE DISABLED
(Notes 8 and 12, Figure 2) T V A = +25°C 300 900 Turn-On Time t NO_ _ = 1.5V, ONSD ns RL = 5kΩ, CL = 35pF TA = TMIN to TMAX 1000 T V A = +25°C 100 300 Turn-Off Time t NO_ _ = 1.5V, OFFSD ns RL = 300Ω, CL = 35pF TA = TMIN to TMAX 400 Break-Before-Make Time tBBM VNO_ _ = 1.5V, TA = TMIN to TMAX 10 200 ns
DYNAMIC TIMING WITH CLICKLESS MODE ENABLED
(Notes 8 and 12, Figure 2) VNO_ _ = 1.5V, RL = 5kΩ, CL = 35pF, Turn-On Time tONSE 8 ms TA = +25°C VNO_ _ = 1.5V, RL = 300Ω, CL = 35pF, Turn-Off Time tOFFSE 3 ms TA = +25°C
4 _______________________________________________________________________________________
