DatasheetsDatasheet RDA5807M (RDA Microelectronics)
Manufacturer | RDA Microelectronics |
Description | Single-Chip Broadcast FM Radio Tuner |
Pages / Page | 23 / 1 — RDA5807M. SINGLE-CHIP BROADCAST FM RADIO TUNER. General Description. 1.1. … |
Revision | 1.0 |
File Format / Size | PDF / 775 Kb |
RDA5807M. SINGLE-CHIP BROADCAST FM RADIO TUNER. General Description. 1.1. Features. 1.2. Applications
RDA5807M SINGLE-CHIP BROADCAST FM RADIO TUNER
Rev.1.0–May.2011
1 General Description
The RDA5807M series is the newest generation single-chip broadcast FM stereo radio tuner with fully integrated 1 GND LOUT 10 synthesizer, IF selectivity, RDS/RBDS and MPX decoder. The tuner uses the CMOS process, support multi-interface 2 FMIN ROUT 9 and require the least external component. All these make it GND GND very suitable for portable devices. 3 RDA5807M 8 4 SCLK VDD 7 The RDA5807M series has a powerful low-IF digital audio processor, this make it have optimum sound quality with 5 SDIO RCLK 6 varying reception conditions. The RDA5807M series support frequency range is from Figure1-1. RDA5807M Top View 50MHz to 115MHz.
1.1 Features
CMOS single-chip ful y-integrated FM tuner Mono/stereo switch Low power consumption Soft mute Total current consumption lower than 20mA at 3.0V High cut power supply when under normal situation Programmable de-emphasis (50/75 s) Support worldwide frequency band Receive signal strength indicator (RSSI) and SNR 50 -115 MHz Bass boost Support flexible channel spacing mode Volume control and mute 100KHz, 200KHz, 50KHz and 25KHz Line-level analog output voltage Support RDS/RBDS 32.768 KHz 12M,24M,13M,26M,19.2M,38.4MHz Digital low-IF tuner Reference clock Image-reject down-converter Only support 2-wire bus interface High performance A/D converter Directly support 32Ω resistance loading IF selectivity performed internaly Integrated LDO regulator Fuly integrated digital frequency synthesizer 1.8 to 3.3 V operation voltage Fuly integrated on-chip RF and IF VCO MSOP-10pins Fuly integrated on-chip loop filter Autonomous search tuning
1.2 Applications
Support 32.768KHz crystal oscilator Celular handsets Digital auto gain control (AGC) MP3, MP4 players Digital adaptive noise cancelation Portable radios
Copyright © RDA Microelectronics Inc. 2006. All rights are reserved.
The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA.
