Datasheet PVT412PbF (Infineon) - 2
Manufacturer | Infineon |
Description | HEXFET Power MOSFET Photovoltaic Relay Single-Pole, Normally-Open, 0-400V, 140mA AC/DC |
Pages / Page | 6 / 2 — Electrical Specifications. INPUT CHARACTERISTICS. Part Numbers. Units. … |
File Format / Size | PDF / 270 Kb |
Electrical Specifications. INPUT CHARACTERISTICS. Part Numbers. Units. OUTPUT CHARACTERISTICS. GENERAL CHARACTERISTICS
Series PVT412PbF
(-40°C ≤ TA ≤ +85°C unless otherwise specified)
INPUT CHARACTERISTICS Part Numbers Units
PVT412L PVT412 Minimum Control Current (see figures 1 and 2) 3.0 mA Maximum Control Current for Off-State Resistance 0.4 mA Control Current Range (Caution: current limit input LED, see figure 6) 3.0 to 25 mA Maximum Reverse Voltage 6.0 V
PVT412L PVT412 Operating Voltage Range 0 to ±400 V(DC or AC peak) Maximum Load Current @ TA=+40°C 5mA Control (see figures1 and 2) A Connection 120 140 mA (AC or DC) B Connection 130 150 mA (DC) C Connection 200 210 mA (DC) Maximum On-State Resistance @TA=+25°C For 50mA Pulsed Load, 5mA Control (see figure 4) A Connection 35 27 Ω B Connection 18 14 Ω C Connection 9 7 Ω Maximum Off-State Leakage @TA=+25°C, ±400V (see figure 5) 1.0 µA Current Limit @TA=+25°C, For 5mA Control Current: Connection:
A C
Minimum 130 260 n/a mA Maximum 220 440 n/a mA Complies with FCC Part 68 Surge Requirements* yes yes Maximum Turn-On Time @TA=+25°C (see figure 7) For 50mA, 100 VDC load, 5mA Control 2.0 ms Maximum Turn-Off Time @TA=+25°C (see figure 7) For 50mA, 100 VDC load, 5mA Control 0.5 ms Maximum Thermal Offset Voltage @ 5mA Control 0.5 µV Maximum Output Capacitance @ 50VDC 12 pF
ALL MODELS Minimum Dielectric Strength, Input-Output 4000 VRMS Minimum Insulation Resistance, Input-Output @TA=+25°C, 50%RH, 100VDC 1012 Ω Maximum Capacitance, Input-Output 1.0 pF Maximum Pin Soldering Temperature (10 seconds maximum) +260 Ambient Temperature Range: Operating -40 to +85 °C Storage -40 to +100 International Rectifier does not recommend the use of this product in aerospace, avionics, military or life support applications. Users of this International Rectifier product in such applications assume all risks of such use and indemnify International Rectifier against all damages resulting from such use. 2 www.irf.com © 2015 International Rectifier Submit Datasheet Feedback May 18, 2015
