Datasheet CR2450 (EEMB) - 9
ManufacturerEEMB
DescriptionEEMB Li-MnO2 Battery
Pages / Page9 / 9 — CR2450 Datasheet. EEMB Li-MnO2 Battery. Discharge through Conductive …
File Format / SizePDF / 388 Kb
CR2450 Datasheet. EEMB Li-MnO2 Battery. Discharge through Conductive Electrostatic Prevention Mats
CR2450 Datasheet EEMB Li-MnO2 Battery Discharge through Conductive Electrostatic Prevention Mats
(Edition: Apr. 2016)
Conductive mats are widely used to prevent static electricity from destroying semiconductors. If a circuit board with a battery mounted in put on a conductive mat, the soldered conductors may touch the mat, providing a discharge path for the battery.
Improper Battery Mounting Polarity
When the battery's positive (+) and negative (-) terminals are backward with respect to the battery mounting's polarity marks, the battery may be discharged, depending on the type of electriccircuit.
Solder
When the battery's lead plates are dipped in a molten solder bath, the battery is temporarily short-circuited. Therefore, complete dipping within 5 seconds. EEMB reserves the final explanation. Please use battery strictly according to specification. EEMB will not be responsible for any inappropriate operation. EEMB keeps the right to change product specifications without previous notice. If any question, please consult with the manufacturer 9 Document Outline EEMB CO., LTD Specification Battery Structure Scope Features and Applications Battery Basic Characteristics Performance and Test Methods Characteristics Curve Matters Needing Attention ! Caution ! Danger ! Warning ! Storage and Mount Overlapping Batteries Batteries put in a Metallic Container or on a Meta When a Battery is Held with Tweezers When Battery Lead Plates Touch Each Other Solder Bridges Short-circuited though Soldering Iron Shorts through Piled Circuit Board Discharge through Conductive Electrostatic Prevent Improper Battery Mounting Polarity Solder
