Datasheet MAX4100, MAX4101 (Maxim)
ManufacturerMaxim
Description500MHz, Low-Power Op Amps
Pages / Page12 / 1 — EVALUATION KIT. AVAILABLE. 500MHz, Low-Power Op Amps. MAX4100/MAX4101. …
File Format / SizePDF / 148 Kb
EVALUATION KIT. AVAILABLE. 500MHz, Low-Power Op Amps. MAX4100/MAX4101. _______________General Description
Datasheet MAX4100, MAX4101 Maxim
19-0436; Rev 1; 3/96
EVALUATION KIT AVAILABLE 500MHz, Low-Power Op Amps MAX4100/MAX4101 _______________General Description ____________________________Features
The MAX4100/MAX4101 op amps combine ultra-high- ♦
500MHz Unity-Gain Bandwidth (MAX4100)
speed performance with low-power operation. The
200MHz -3dB Bandwidth (AVCL = 2V/V, MAX4101)
MAX4100 is compensated for unity-gain stability, while the MAX4101 is compensated for stability in applica- ♦
65MHz 0.1dB Gain Flatness (MAX4100)
tions with a closed-loop gain (AVCL) of 2V/V or greater. ♦
250V/µs Slew Rate
The MAX4100/MAX4101 require only 5mA of supply current while delivering a 500MHz unity-gain bandwidth ♦
0.06%/0.04° Differential Gain/Phase
(MAX4100) or a 200MHz -3dB bandwidth (MAX4101) ♦
High Output Drive: 80mA
with a 250V/µs slew rate. ♦
Low Power: 5mA Supply Current
These high-speed op amps have a wide output voltage swing of ±3.5V and a high current-drive capability of ♦
Fast Settling Time:
80mA.
18ns to 0.1% 35ns to 0.01% ________________________Applications ______________Ordering Information
Video Cable Driver
PART TEMP. RANGE PIN-PACKAGE
Ultrasound
MAX4100
ESA -40°C to +85°C 8 SO Gamma Cameras MAX4100EUA -40°C to +85°C 8 µMAX*
MAX4101
ESA -40°C to +85°C 8 SO Portable Instruments * Contact factory for availability of µMAX package. Active Filters ADC Buffers
________Typical Application Circuit __________________Pin Configuration
+5V TOP VIEW 0.1µF 1000pF INPUT 75Ω MAX4100 MAX4101 75Ω N.C. 1 8 N.C. 75Ω IN- 2 7 VCC MAX4100 0.1µF MAX4101 1000pF IN+ 3 6 OUT 75Ω -5V VEE 4 5 N.C. 390Ω 75Ω
SO/
µ
MAX*
390Ω 75Ω * Contact factory for availability of MAX4100 µMAX package.
VIDEO/RF DISTRIBUTION AMPLIFIER ________________________________________________________________ Maxim Integrated Products 1 For free samples & the latest literature: http://www.maxim-ic.com, or phone 1-800-998-8800
