Datasheet AM2431, AM2432, AM2434 (Texas Instruments) - 306
ManufacturerTexas Instruments
DescriptionArm Cortex-R5F based MCU with industrial communications and security up to 800MHz
Pages / Page316 / 306 — AM2434. , AM2432, AM2431. www.ti.com. 10.3 Documentation Support. …
File Format / SizePDF / 6.4 Mb
AM2434. , AM2432, AM2431. www.ti.com. 10.3 Documentation Support. Technical Reference Manual
AM2434 , AM2432, AM2431 www.ti.com 10.3 Documentation Support Technical Reference Manual
SPRSP65B – APRIL 2021 – REVISED JULY 2021
To receive notification of documentation updates, navigate to the device product folder on ti.com. In the upper right corner, click on Alert me to register and receive a weekly digest of any product information that has changed. For change details, review the revision history included in any revised document. The current documentation that describes the processor, related peripherals, and other technical collateral is listed below. The following documents describe the AM243x family of devices.
Technical Reference Manual AM64x/AM243x Processors Silicon Revision 1.0 Technical Reference Manual
Details the integration, the environment, the functional description, and the programming models for each peripheral and subsystem in the AM243x family of devices.
AD Errata V AM64x/AM243x Processors Silicon Revision 1.0 Silicon Errata
Describes the known exceptions to the
A
functional specifications for the device.
NCE INFO Tip
: Search TI.com using literature numbers.
10.4 Support Resources
TI E2E™ support forums are an engineer's go-to source for fast, verified answers and design help — straight from the experts. Search existing answers or ask your own question to get the quick design help you need. Linked content is provided "AS IS" by the respective contributors. They do not constitute TI specifications and do
R
not necessarily reflect TI's views; see TI's Terms of Use.
MA 10.5 Trademarks TION
CoreSight™ is a trademark of Arm Limited (or its subsidiaries) in the US and/or elsewhere. Code Composer Studio™ is a trademark of TI. TI E2E™ is a trademark of Texas Instruments. Arm®, Cortex®, TrustZone® are registered trademarks of Arm Limited. PCI-Express® are registered trademarks of PCI-SIG. EtherCAT® is a registered trademark of Beckhoff Automation GmbH. All trademarks are the property of their respective owners.
10.6 Electrostatic Discharge Caution
This integrated circuit can be damaged by ESD. Texas Instruments recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications.
10.7 Glossary
TI Glossary This glossary lists and explains terms, acronyms, and definitions. 306 Submit Document Feedback Copyright © 2021 Texas Instruments Incorporated Product Folder Links: AM2434 AM2432 AM2431 Document Outline 1 Features 2 Applications 3 Description 3.1 Functional Block Diagram Table of Contents 4 Revision History 5 Device Comparison 5.1 Related Products 6 Terminal Configuration and Functions 6.1 Pin Diagram 6.1.1 AM243x ALV Pin Diagram 6.1.2 AM243x ALX Pin Diagram 6.2 Pin Attributes (ALV Package) 6.3 Pin Attributes (ALX Package) 6.4 Signal Descriptions 6.4.1 ADC MAIN Domain Instances 6.4.1.1 ADC0 Signal Descriptions 6.4.2 DDRSS MAIN Domain Instances 6.4.2.1 DDRSS0 Signal Descriptions 6.4.3 GPIO MAIN Domain Instances 6.4.3.1 GPIO0 Signal Descriptions 6.4.3.2 GPIO1 Signal Descriptions MCU Domain Instances 6.4.3.3 MCU_GPIO0 Signal Descriptions 6.4.4 I2C MAIN Domain Instances 6.4.4.1 I2C0 Signal Descriptions 6.4.4.2 I2C1 Signal Descriptions 6.4.4.3 I2C2 Signal Descriptions 6.4.4.4 I2C3 Signal Descriptions MCU Domain Instances 6.4.4.5 MCU_I2C0 Signal Descriptions 6.4.4.6 MCU_I2C1 Signal Descriptions 6.4.5 MCAN MAIN Domain Instances 6.4.5.1 MCAN0 Signal Descriptions 6.4.5.2 MCAN1 Signal Descriptions 6.4.6 SPI (MCSPI) MAIN Domain Instances 6.4.6.1 MCSPI0 Signal Descriptions 6.4.6.2 MCSPI1 Signal Descriptions 6.4.6.3 MCSPI2 Signal Descriptions 6.4.6.4 MCSPI3 Signal Descriptions 6.4.6.5 MCSPI4 Signal Descriptions MCU Domain Instances 6.4.6.6 MCU_MCSPI0 Signal Descriptions 6.4.6.7 MCU_MCSPI1 Signal Descriptions 6.4.7 UART MAIN Domain Instances 6.4.7.1 UART0 Signal Descriptions 6.4.7.2 UART1 Signal Descriptions 6.4.7.3 UART2 Signal Descriptions 6.4.7.4 UART3 Signal Descriptions 6.4.7.5 UART4 Signal Descriptions 6.4.7.6 UART5 Signal Descriptions 6.4.7.7 UART6 Signal Descriptions MCU Domain Instances 6.4.7.8 MCU_UART0 Signal Descriptions 6.4.7.9 MCU_UART1 Signal Descriptions 6.4.8 MDIO MAIN Domain Instances 6.4.8.1 MDIO0 Signal Descriptions 6.4.9 CPSW MAIN Domain Instances 6.4.9.1 CPSW3G0 Signal Descriptions 6.4.10 ECAP MAIN Domain Instances 6.4.10.1 ECAP0 Signal Descriptions 6.4.10.2 ECAP1 Signal Descriptions 6.4.10.3 ECAP2 Signal Descriptions EQEP MAIN Domain Instances 6.4.11.1 EQEP0 Signal Descriptions 6.4.11.2 EQEP1 Signal Descriptions 6.4.11.3 EQEP2 Signal Descriptions 6.4.11 EPWM MAIN Domain Instances 6.4.11.1 EPWM Signal Descriptions 6.4.11.2 EPWM0 Signal Descriptions 6.4.11.3 EPWM1 Signal Descriptions 6.4.11.4 EPWM2 Signal Descriptions 6.4.11.5 EPWM3 Signal Descriptions 6.4.11.6 EPWM4 Signal Descriptions 6.4.11.7 EPWM5 Signal Descriptions 6.4.11.8 EPWM6 Signal Descriptions 6.4.11.9 EPWM7 Signal Descriptions 6.4.11.10 EPWM8 Signal Descriptions 6.4.12 SERDES MAIN Domain Instances 6.4.12.1 SERDES0 Signal Descriptions 6.4.13 USB MAIN Domain Instances 6.4.13.1 USB0 Signal Descriptions 6.4.14 OSPI MAIN Domain Instances 6.4.14.1 OSPI0 Signal Descriptions 6.4.15 GPMC MAIN Domain Instances 6.4.15.1 GPMC0 Signal Descriptions 6.4.16 MMC MAIN Domain Instances 6.4.16.1 MMC0 Signal Descriptions 6.4.16.2 MMC1 Signal Descriptions 6.4.17 FSITX MAIN Domain Instances 6.4.17.1 FSI0 TX Signal Descriptions 6.4.17.2 FSI1 TX Signal Descriptions 6.4.18 FSIRX MAIN Domain Instances 6.4.18.1 FSI0 RX Signal Descriptions 6.4.18.2 FSI1 RX Signal Descriptions 6.4.18.3 FSI2 RX Signal Descriptions 6.4.18.4 FSI3 RX Signal Descriptions 6.4.18.5 FSI4 RX Signal Descriptions 6.4.18.6 FSI5 RX Signal Descriptions 6.4.19 CPTS MAIN Domain Instances 6.4.19.1 CPTS0 Signal Descriptions 6.4.19.2 CP GEMAC CPTS0 Signal Descriptions 6.4.20 ICSSG MAIN Domain Instances 6.4.20.1 PRU_ICSSG0 Signal Descriptions 6.4.20.2 PRU_ICSSG1 Signal Descriptions 6.4.21 DMTIMER MAIN Domain Instances 6.4.21.1 DMTIMER Signal Descriptions MCU Domain Instances 6.4.21.2 MCU_DMTIMER Signal Descriptions 6.4.22 TRACE MAIN Domain Instances 6.4.22.1 Trace Signal Descriptions 6.4.23 JTAG MAIN Domain Instances 6.4.23.1 JTAG Signal Descriptions 6.4.24 SYSBOOT MAIN Domain Instances 6.4.24.1 Sysboot Signal Descriptions 6.4.25 SYSTEM MAIN Domain Instances 6.4.25.1 System Signal Descriptions MCU Domain Instances 6.4.25.2 MCU System Signal Descriptions 6.4.26 CLOCK MCU Domain Instances 6.4.26.1 MCU Clock Signal Descriptions 6.4.27 VMON 6.4.27.1 VMON Signal Description 6.4.28 Power Supply 6.4.28.1 Power Supply Signal Description 6.5 Pin Multiplexing 6.6 Connections for Unused Pins 7 Specifications 7.1 Absolute Maximum Ratings 7.2 ESD Ratings 7.3 Power-On Hours (POH) 7.4 Recommended Operating Conditions 7.5 Operating Performance Points 7.6 Power Consumption Summary 7.7 Electrical Characteristics 7.7.1 Fail-Safe Reset (FS RESET) Electrical Characteristics 7.7.2 I2C Open-Drain, and Fail-Safe (I2C OD FS) Electrical Characteristics 7.7.3 High-Frequency Oscillator (HFOSC) Electrical Characteristics 7.7.4 eMMCPHY Electrical Characteristics 7.7.5 SDIO Electrical Characteristics 7.7.6 ADC12B Electrical Characteristics 7.7.7 LVCMOS Electrical Characteristics 7.7.8 USB2PHY Electrical Characteristics 7.7.9 DDR Electrical Characteristics 7.8 VPP Specifications for One-Time Programmable (OTP) eFuses 7.8.1 Recommended Operating Conditions for OTP eFuse Programming 7.8.2 Hardware Requirements 7.8.3 Programming Sequence 7.8.4 Impact to Your Hardware Warranty 7.9 Thermal Resistance Characteristics 7.9.1 Thermal Resistance Characteristics 7.10 Timing and Switching Characteristics 7.10.1 Timing Parameters and Information 7.10.2 Power Supply Sequencing 7.10.2.1 Power Supply Slew Rate Requirement 7.10.2.2 Power-Up Sequencing 7.10.2.3 Power-Down Sequencing 7.10.3 System Timing 7.10.3.1 Reset Timing 7.10.3.2 Safety Signal Timing 7.10.3.3 Clock Timing 7.10.4 Clock Specifications 7.10.4.1 Input Clocks / Oscillators 7.10.4.1.1 MCU_OSC0 Internal Oscillator Clock Source 7.10.4.1.1.1 Load Capacitance 7.10.4.1.1.2 Shunt Capacitance 7.10.4.1.2 MCU_OSC0 LVCMOS Digital Clock Source 7.10.4.2 Output Clocks 7.10.4.3 PLLs 7.10.5 Peripherals 7.10.5.1 CPSW3G 7.10.5.1.1 CPSW3G MDIO Timing 7.10.5.1.2 CPSW3G RMII Timing 7.10.5.1.3 CPSW3G RGMII Timing 7.10.5.2 DDRSS 7.10.5.3 ECAP 7.10.5.4 EPWM 7.10.5.5 EQEP 7.10.5.6 FSI 7.10.5.7 GPIO 7.10.5.8 GPMC 7.10.5.8.1 GPMC and NOR Flash — Synchronous Mode 7.10.5.8.2 GPMC and NOR Flash — Asynchronous Mode 7.10.5.8.3 GPMC and NAND Flash — Asynchronous Mode 7.10.5.9 I2C 7.10.5.9.1 Timing Requirements for I2C Input Timings 7.10.5.10 MCAN 7.10.5.11 MCSPI 7.10.5.11.1 MCSPI — Master Mode 7.10.5.11.2 MCSPI — Slave Mode 7.10.5.12 MMCSD 7.10.5.12.1 MMC0 - eMMC Interface 7.10.5.12.1.1 Legacy SDR Mode 7.10.5.12.1.2 High Speed SDR Mode 7.10.5.12.1.3 High Speed DDR Mode 7.10.5.12.1.4 HS200 Mode 7.10.5.12.2 MMC1 - SD/SDIO Interface 7.10.5.12.2.1 Default Speed Mode 7.10.5.12.2.2 High Speed Mode 7.10.5.12.2.3 UHS–I SDR12 Mode 7.10.5.12.2.4 UHS–I SDR25 Mode 7.10.5.12.2.5 UHS–I SDR50 Mode 7.10.5.12.2.6 UHS–I DDR50 Mode 7.10.5.12.2.7 UHS–I SDR104 Mode 7.10.5.13 CPTS 7.10.5.14 OSPI 7.10.5.14.1 OSPI With Data Training 7.10.5.14.1.1 OSPI Switching Characteristics – Data Training 7.10.5.14.2 OSPI Without Data Training 7.10.5.14.2.1 OSPI SDR Timing 7.10.5.14.2.2 OSPI DDR Timing 7.10.5.15 PCIe 7.10.5.16 PRU_ICSSG 7.10.5.16.1 PRU_ICSSG Programmable Real-Time Unit (PRU) 7.10.5.16.1.1 PRU_ICSSG PRU Direct Output Mode Timing 7.10.5.16.1.2 PRU_ICSSG PRU Parallel Capture Mode Timing 7.10.5.16.1.3 PRU_ICSSG PRU Shift Mode Timing 7.10.5.16.1.4 PRU_ICSSG PRU Sigma Delta and Peripheral Interface 7.10.5.16.1.4.1 PRU_ICSSG PRU Sigma Delta and Peripheral Interface Timing 7.10.5.16.2 PRU_ICSSG Pulse Width Modulation (PWM) 7.10.5.16.2.1 PRU_ICSSG PWM Timing 7.10.5.16.3 PRU_ICSSG Industrial Ethernet Peripheral (IEP) 7.10.5.16.3.1 PRU_ICSSG IEP Timing 7.10.5.16.4 PRU_ICSSG Universal Asynchronous Receiver Transmitter (UART) 7.10.5.16.4.1 PRU_ICSSG UART Timing 7.10.5.16.5 PRU_ICSSG Enhanced Capture Peripheral (ECAP) 7.10.5.16.5.1 PRU_ICSSG ECAP Timing 7.10.5.16.6 PRU_ICSSG RGMII, MII_RT, and Switch 7.10.5.16.6.1 PRU_ICSSG MDIO Timing 7.10.5.16.6.2 PRU_ICSSG MII Timing 7.10.5.16.6.3 PRU_ICSSG RGMII Timing 7.10.5.17 Timers 7.10.5.18 UART 7.10.5.19 USB 7.10.6 Emulation and Debug 7.10.6.1 Trace 7.10.6.2 JTAG 8 Detailed Description 8.1 Overview 8.2 Processor Subsystems 8.2.1 Arm Cortex-R5F Subsystem (R5FSS) 8.2.2 Arm Cortex-M4F (M4FSS) 8.3 Accelerators and Coprocessors 8.3.1 Programmable Real-Time Unit Subsystem and Industrial Communication Subsystem (PRU_ICSSG) 8.4 Other Subsystems 8.4.1 PDMA Controller 8.4.2 Peripherals 8.4.2.1 ADC 8.4.2.2 DCC 8.4.2.3 Dual Date Rate (DDR) External Memory Interface (DDRSS) 8.4.2.4 ECAP 8.4.2.5 EPWM 8.4.2.6 ELM 8.4.2.7 ESM 8.4.2.8 GPIO 8.4.2.9 EQEP 8.4.2.10 GPMC 8.4.2.11 I2C 8.4.2.12 MCAN 8.4.2.13 MCRC Controller 8.4.2.14 MCSPI 8.4.2.15 MMCSD 8.4.2.16 OSPI 8.4.2.17 Peripheral Component Interconnect Express (PCIe) 8.4.2.18 Serializer/Deserializer (SerDes) 8.4.2.19 RTI 8.4.2.20 DMTIMER 8.4.2.21 UART 8.4.2.22 Universal Serial Bus Subsystem(USBSS) 9 Applications, Implementation, and Layout 9.1 Power Supply Mapping 9.2 Device Connection and Layout Fundamentals 9.2.1 Power Supply Decoupling and Bulk Capacitors 9.2.1.1 Power Distribution Network Implementation Guidance 9.2.2 External Oscillator 9.2.3 JTAG and EMU 9.2.4 Unused Pins 9.3 Peripheral- and Interface-Specific Design Information 9.3.1 General Routing Guidelines 9.3.2 DDR Board Design and Layout Guidelines 9.3.3 OSPI and QSPI Board Design and Layout Guidelines 9.3.3.1 No Loopback and Internal Pad Loopback 9.3.3.2 External Board Loopback 9.3.3.3 DQS (only available in Octal Flash devices) 9.3.4 USB VBUS Design Guidelines 9.3.5 System Power Supply Monitor Design Guidelines 9.3.6 High Speed Differential Signal Routing Guidance 9.3.7 Thermal Solution Guidance 10 Device and Documentation Support 10.1 Device Nomenclature 10.1.1 Standard Package Symbolization 10.1.2 Device Naming Convention 10.2 Tools and Software 10.3 Documentation Support 10.4 Support Resources 10.5 Trademarks 10.6 Electrostatic Discharge Caution 10.7 Glossary 11 Mechanical, Packaging, and Orderable Information 11.1 Packaging Information
