Datasheet MLX90614 (Melexis)
ManufacturerMelexis
DescriptionSingle and Dual Zone Infra Red Thermometer in TO-39
Pages / Page57 / 1 — MLX90614 family. Features and Benefits. Application Examples. Ordering …
File Format / SizePDF / 2.9 Mb
MLX90614 family. Features and Benefits. Application Examples. Ordering Information. Part No. Temperature. Package. - Option Code
Datasheet MLX90614 Melexis
MLX90614
MLX90614 family
Datasheet Single and Dual Zone Infra Red Thermometer in TO-39
Features and Benefits Application Examples
Small size, low cost High precision non-contact temperature Easy to integrate measurements Factory calibrated in wide temperature Thermal Comfort sensor for Mobile Air range: Conditioning control system -40°C…+125˚C for sensor temperature and Temperature sensing element for -70°C…+380˚C for object temperature. residential, commercial and industrial High accuracy of 0.5°C in a wide building air conditioning temperature range (0°C…+50°C for both Ta Windshield defogging and To) Automotive blind angle detection High (medical) accuracy calibration Industrial temperature control of moving Measurement resolution of 0.02°C parts Single and dual zone versions Temperature control in printers and SMBus compatible digital interface copiers Customizable PWM output for continuous Home appliances with temperature control reading Healthcare Available in 3V and 5V versions Livestock monitoring Simple adaptation for 8V…16V applications Movement detection Sleep mode for reduced power Multiple zone temperature control – up to consumption 127 sensors can be read via common 2 Different package options for applications wires and measurements versatility Thermal relay / alert Body temperature measurement Automotive grade
Ordering Information Part No. Temperature Package - Option Code Standard Packing Code Code
- X X X
part form
MLX90614 E (-40°C...85°C) SF (TO-39) (1) (2) (3) -000 -TU K (-40°C…125°C) (1) Supply Voltage/ Accuracy (2) Number of thermopiles: (3) Package options: A - 5V A – single zone A – Standard package B - 3V B – dual zone B – Reserved C - Reserved C – gradient compensated* C – 35° FOV D - 3V medical accuracy D/E – Reserved F – 10° FOV G – Reserved H – 12° FOV (refractive lens) I – 5° FOV K – 13°FOV
Example:
MLX90614ESF-BAA-000-TU
* : See page 2
REVISION 13 - 13 SEPTEMBER, 2019 3901090614
