Datasheet H21B1, H21B2, H21B3 (Fairchild) - 6
Manufacturer | Fairchild |
Description | Photodarlington Optical Interrupter Switch |
Pages / Page | 6 / 6 — PHOTODARLINGTON. OPTICAL INTERRUPTER SWITCH. H21B1 H21B2 H21B3. … |
File Format / Size | PDF / 393 Kb |
PHOTODARLINGTON. OPTICAL INTERRUPTER SWITCH. H21B1 H21B2 H21B3. DISCLAIMER. LIFE SUPPORT POLICY
PHOTODARLINGTON OPTICAL INTERRUPTER SWITCH H21B1 H21B2 H21B3 DISCLAIMER
FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS.
LIFE SUPPORT POLICY
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF THE PRESIDENT OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems 2. A critical component in any component of a life support which, (a) are intended for surgical implant into the body, or device or system whose failure to perform can be (b) support or sustain life, and (c) whose failure to perform reasonably expected to cause the failure of the life support when properly used in accordance with instructions for use device or system, or to affect its safety or effectiveness. provided in the labeling, can be reasonably expected to result in a significant injury of the user. © 2002 Fairchild Semiconductor Corporation Page 6 of 6 6/13/02
