Datasheet MUR405, MUR410, MUR415, MUR420, MUR440, MUR460 (ON Semiconductor) - 8
Manufacturer | ON Semiconductor |
Description | Switch-Mode Power Rectifiers |
Pages / Page | 9 / 8 — PACKAGE DIMENSIONS. AXIAL LEAD. CASE 267−05. ISSUE G. DATE 06/06/2000. … |
Revision | 16 |
File Format / Size | PDF / 192 Kb |
PACKAGE DIMENSIONS. AXIAL LEAD. CASE 267−05. ISSUE G. DATE 06/06/2000. SCALE 1:1. INCHES. MILLIMETERS. DIM. MIN. MAX
MECHANICAL CASE OUTLINE
PACKAGE DIMENSIONS AXIAL LEAD CASE 267−05 ISSUE G DATE 06/06/2000 SCALE 1:1
NOTES: 1. DIMENSIONS AND TOLERANCING PER ANSI
K A
Y14.5M, 1982.
D
2. CONTROLLING DIMENSION: INCH. 3. 267-04 OBSOLETE, NEW STANDARD 267-05.
1 2 INCHES MILLIMETERS DIM MIN MAX MIN MAX A
0.287 0.374 7.30 9.50
B B
0.189 0.209 4.80 5.30
K D
0.047 0.051 1.20 1.30
K
1.000 --- 25.40 --- STYLE 1: STYLE 2: PIN 1. CATHODE (POLARITY BAND) NO POLARITY 2. ANODE
DOCUMENT NUMBER: 98ASB42170B
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: AXIAL LEAD PAGE 1 OF 1
ON Semiconductor and are trademarks of Semiconductor Components Industries, LLC dba ON Semiconductor or its subsidiaries in the United States and/or other countries. ON Semiconductor reserves the right to make changes without further notice to any products herein. ON Semiconductor makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ON Semiconductor assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. ON Semiconductor does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2019 www.onsemi.com
