Datasheet MPSH81, MMBTH81 (ON Semiconductor) - 10
ManufacturerON Semiconductor
DescriptionPNP RF Transistor
Pages / Page13 / 10 — SOT-23 Tape and Reel Data, continued. SOT-23 Embossed Carrier Tape. …
File Format / SizePDF / 598 Kb
SOT-23 Tape and Reel Data, continued. SOT-23 Embossed Carrier Tape. Configuration: Figure 3.0. P0 P2 D1 D0 T. E1 W F
SOT-23 Tape and Reel Data, continued SOT-23 Embossed Carrier Tape Configuration: Figure 3.0 P0 P2 D1 D0 T E1 W F
P0 P2 D1 D0 T
E1 W F
E2
Wc B0 Tc A0 P1 K0 User Direction of Feed Dimensions are in millimeter
Pkg type A0 B0 SOT-23
(8mm) 3.15
+/-0.10 2.77
+/-0.10 W
8.0
+/-0.3 D0 D1 E1 E2 1.55
+/-0.05 1.125
+/-0.125 1.75
+/-0.10 F 6.25
min 3.50
+/-0.05 P1 P0 4.0
+/-0.1 4.0
+/-0.1 K0 T 1.30
+/-0.10 0.228
+/-0.013 Notes: A0, B0, and K0 dimensions are determined with respect to the EIA/Jedec RS-481
rotational and lateral movement requirements (see sketches A, B, and C). Wc 0.06
+/-0.02 0.5mm
maximum 20 deg maximum
Typical
component
cavity
center line B0 5.2
+/-0.3 Tc 0.5mm
maximum 20 deg maximum component rotation
Typical
component
center line Sketch A (Side or Front Sectional View)
A0 Component Rotation Sketch C (Top View) Component lateral movement Sketch B (Top View) SOT-23 Reel Configuration: Figure 4.0 Component Rotation W1 Measured at Hub Dim A
Max Dim A
max See detail AA Dim N 7" Diameter Option
B Min
Dim C
See detail AA
W3 13" Diameter Option Dim D
min W2 max Measured at Hub
DETAIL AA Dimensions are in inches and millimeters
Tape Size Reel
Option Dim A Dim B Dim C Dim D Dim N Dim W1 Dim W2 Dim W3 (LSL-USL) 8mm 7" Dia 7.00
177.8 0.059
1.5 512 +0.020/-0.008
13 +0.5/-0.2 0.795
20.2 2.165
55 0.331 +0.059/-0.000
8.4 +1.5/0 0.567
14.4 0.311 – 0.429
7.9 – 10.9 8mm 13" Dia 13.00
330 0.059
13 +0.5/-0.2 0.795
20.2 4.00
100 0.331 +0.059/-0.000
8.4 +1.5/0 0.567
14.4 0.311 – 0.429
7.9 – 10.9 September 1999, Rev. C
