Datasheet MPSA42, MMBTA42, PZTA42 (Fairchild)
ManufacturerFairchild
DescriptionNPN High Voltage Amplifier
Pages / Page14 / 1 — MPSA42 / MMBT. MPSA42. MMBTA42. PZTA42. A42 / PZT. A42. TO-92. SOT-23. …
File Format / SizePDF / 903 Kb
MPSA42 / MMBT. MPSA42. MMBTA42. PZTA42. A42 / PZT. A42. TO-92. SOT-23. SOT-223. Mark: 1D. NPN High Voltage Amplifier
Datasheet MPSA42, MMBTA42, PZTA42 Fairchild
MPSA42 / MMBT MPSA42 MMBTA42 PZTA42 A42 / PZT C C E E A42 C C TO-92 B B SOT-23 B E SOT-223 Mark: 1D NPN High Voltage Amplifier
This device is designed for application as a video output to drive color CRT and other high voltage applications. Sourced from Process 48.
Absolute Maximum Ratings*
TA = 25°C unless otherwise noted
Symbol Parameter Value Units
VCES Collector-Emitter Voltage 300 V VCBO Collector-Base Voltage 300 V VEBO Emitter-Base Voltage 6.0 V IC Collector Current - Continuous 500 mA TJ, Tstg Operating and Storage Junction Temperature Range -55 to +150 °C *These ratings are limiting values above which the serviceability of any semiconductor device may be impaired.
NOTES
1)
These ratings are based on a maximum junction temperature of 150 degrees C.
2)
These are steady state limits. The factory should be consulted on applications involving pulsed or low duty cycle operations.
Thermal Characteristics
Symbol Characteristic Max Units MPSA42 *MMBTA42 **PZTA42
PD Total Device Dissipation 625 350 1,000 mW Derate above 25°C 5.0 2.8 8.0 mW/°C RθJC Thermal Resistance, Junction to Case 83.3 °C/W RθJA Thermal Resistance, Junction to Ambient 200 357 125 °C/W *Device mounted on FR-4 PCB 1.6" X 1.6" X 0.06." **Device mounted on FR-4 PCB 36 mm X 18 mm X 1.5 mm; mounting pad for the collector lead min. 6 cm2. 1997 Fairchild Semiconductor Corporation
