Datasheet MAX1852, MAX1853 (Maxim) - 4
ManufacturerMaxim
DescriptionSC70 Inverting Charge Pump with Shutdown
Pages / Page8 / 4 — SC70 Inverting Charge Pumps with Shutdown. Typical Operating …
File Format / SizePDF / 223 Kb
SC70 Inverting Charge Pumps with Shutdown. Typical Operating Characteristics (continued). MAX1852. MAX1853
SC70 Inverting Charge Pumps with Shutdown Typical Operating Characteristics (continued) MAX1852 MAX1853
(Circuit of Figure 1, capacitors from Table 2, VIN = +5V, SHDN = IN, TA = +25°C, unless otherwise noted.)
MAX1852 MAX1853 CHARGE-PUMP FREQUENCY CHARGE-PUMP FREQUENCY CHARGE-PUMP FREQUENCY vs. TEMPERATURE vs. TEMPERATURE vs. INPUT VOLTAGE
60 230 59 270 225 58 MAX1852/3 toc10 MAX1852/3 toc11 MAX1852/3 toc12 220 MAX1853 57 220 56 170 55 215 54 FREQUENCY (kHz) FREQUENCY (kHz) FREQUENCY (kHz) 120 210 53 52 205 70 MAX1852 51 50 200 20
MAX1852/MAX1853
-40 -20 0 20 40 60 80 -40 -20 0 20 40 60 80 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 TEMPERATURE (°C) TEMPERATURE (°C) INPUT VOLTAGE (V)
MAX1852 AND MAX1853 OUTPUT VOLTAGE RIPPLE MAX1852 OUTPUT VOLTAGE vs. INPUT VOLTAGE vs. CAPACITANCE OUTPUT NOISE AND RIPPLE
-2.0 350 ILOAD = 10mA C1 = C2 C1 = C2 = 4.7µF -2.5 300 ILOAD = 10mA MAX1852/3 toc13 MAX1852/3 toc14 MAX1852/3 toc15 -3.0 250 -3.5 200 VOUT -4.0 150 MAX1852 20mV/div OUTPUT VOLTAGE (V) -4.5 100 OUTPUT VOLTAGE RIPPLE (mV) MAX1853 -5.0 50 -5.5 0 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 0.2 0.7 1.2 1.7 2.2 2.7 3.2 3.7 4.2 4.7 10µs/div INPUT VOLTAGE (V) I CAPACITANCE (µF) LOAD = 10mA, AC-COUPLED
MAX1853 MAX1852 MAX1853 OUTPUT NOISE AND RIPPLE STARTUP FROM SHUTDOWN STARTUP FROM SHUTDOWN
MAX1852/3 toc17 MAX1852/3 toc18 C1 = C2 = 1µF MAX1852/3 toc16 SHDN SHDN 0 2V/div 0 VOUT 2V/div 20mV/div 0 0 VOUT VOUT 2µs/div 100µs/div 40µs/div ILOAD = 10mA, AC-COUPLED
4 _______________________________________________________________________________________
