CBRHD SERIESSURFACE MOUNT SILICONwww.centra lsemi.comHIGH DENSITY0.5 AMPDESCRIPTION:BRIDGE RECTIFIER The CENTRAL SEMICONDUCTOR CBRHD series devices are silicon full wave bridge rectifiers mounted in a durable epoxy surface mount molded case, utilizing glass passivated chips. MARKING CODES:CBRHD-02: CBD2CBRHD-04: CBD4CBRHD-06: CBD6CBRHD-10: CBD10HD DIP CASEFEATURES: • Efficient use of board space: requires only 42mm2 of • 50% higher density (Amps/mm2) than the industry board space vs. 120mm2 of board space needed for standard 1.0 Amp surface mount bridge rectifier. industry standard 1.0 Amp surface mount bridge rectifier. • Glass passivated chips for high reliability. MAXIMUM RATINGS: (TA=25°C unless otherwise noted) CBRHDSYMBOL-02-04-06-10*UNITS Peak Repetitive Reverse Voltage VRRM 200 400 600 1000 V DC Blocking Voltage VR 200 400 600 1000 V RMS Reverse Voltage VR(RMS) 140 280 420 700 V Average Forward Current (TA=40°C) (Note 1) IO 0.5 A Average Forward Current (TA=40°C) (Note 2) IO 0.8 A Peak Forward Surge Current IFSM 30 A Operating & Storage Junction Temperature TJ, Tstg -65 to +150 °C ELECTRICAL CHARACTERISTICS PER DIODE: (TA=25°C unless otherwise noted) SYMBOL TESTCONDITIONSTYPMAXUNITS IR VR=Rated VRRM 5.0 µA IR VR=Rated VRRM, TA=125°C 500 µA VF IF=400mA 1.0 V CJ VR=4.0V, f=1.0MHz 20 pF Notes: (1) Mounted on Glass-Epoxy PCB. (2) Mounted on Ceramic PCB. * Available on special order, please consult factory. R6 (19-August 2020)
