CBRSDSH2-100SURFACE MOUNT SILICONw w w. c e n t r a l s e m i . c o mHIGH DENSITYDESCRIPTION:2.0 AMPSCHOTTKY BRIDGE RECTIFIER The CENTRAL SEMICONDUCTOR CBRSDSH2-100 is a full wave bridge rectifier mounted in a durable epoxy surface mount case, utilizing glass passivated chips. MARKING: FULL PART NUMBERFEATURES:• High 2.0A Current Rating • Low VF Schottky Diodes (700mV MAX @ IF=2.0A) SMDIP CASEMAXIMUM RATINGS: (TA=25°C unless otherwise noted) SYMBOLUNITS Peak Repetitive Reverse Voltage VRRM 100 V DC Blocking Voltage VR 100 V RMS Reverse Voltage VR(RMS) 70 V Average Forward Current (TA=75°C) IO 2.0 A Peak Forward Surge Current (8.3ms) IFSM 110 A Operating Junction Temperature TJ -50 to +125 °C Storage Temperature Tstg -50 to +150 °C ELECTRICAL CHARACTERISTICS PER DIODE: (TA=25°C unless otherwise noted) SYMBOL TESTCONDITIONSTYPMAXUNITS IR VR=100V 1.0 50 μA VF IF=2.0A 650 700 mV CJ VR=4.0V, f=1.0MHz 280 500 pF R3 (4-January 2013)
