Datasheet CMFBR-6F (Central Semiconductor)
DescriptionSURFACE MOUNT SILICON BRIDGE RECTIFIER
Pages / Page4 / 1 — CMFBR-6F. www.centra lsemi.com. SURFACE MOUNT SILICON. BRIDGE RECTIFIER. …
File Format / SizePDF / 465 Kb
CMFBR-6F. www.centra lsemi.com. SURFACE MOUNT SILICON. BRIDGE RECTIFIER. DESCRIPTION:. FEATURES:. SOT-143 CASE. MARKING CODE: CBR2
Datasheet CMFBR-6F Central Semiconductor
CMFBR-6F www.centra lsemi.com SURFACE MOUNT SILICON BRIDGE RECTIFIER DESCRIPTION:
The CENTRAL SEMICONDUCTOR CMFBR-6F is a monolithic silicon full wave bridge rectifier, epoxy molded in a SOT-143 surface mount package. This device has been designed for use in computers and peripheral equipment requiring high speed switching, small size, and closely matched VF.
FEATURES:
• Monolithic construction • Fast switching
SOT-143 CASE
• All diodes share closely matched electrical
MARKING CODE: CBR2
characteristics. • Very small size
MAXIMUM RATINGS:
(TA=25
C)
SYMBOL UNITS
Peak Repetitive Reverse Voltage VRRM 60 V Continuous Forward Current IF 140 mA Power Dissipation PD 350 mW Operating and Storage Junction Temperature TJ, Tstg -65 to +150
C Thermal Resistance ΘJA 357
C/W
ELECTRICAL CHARACTERISTICS PER DIODE:
(TA=25
C unless otherwise noted)
SYMBOL TEST CONDITIONS MIN TYP MAX UNITS
IR VR=50V 10 nA BVR IR=100µA 60 V VF IF=20mA 1.0 V CJ VR= 0V, f=1.0MHz 5.0 pF trr IF=IR=10mA, Irr=1.0mA 1000 ns R5 (19-September 2018)
