MAX9140/MAX9141/ 40ns, Low-Power, 3V/5V, Rail-to-Rail MAX9142/MAX9144 Single-Supply Comparators Electrical Characteristics (continued) (VCC = 5V, VCM = 0V, SHDN = LE = VCC (MAX9141 only), CL = 15pF, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1) PARAMETERSYMBOLCONDITIONSMINTYPMAXUNITS MAX9141 165 275 MAX9140, VCM = VCC = 3V TA = -40°C to 85°C 150 250 MAX9140AA_ _ 360 MAX9142/MAX9144 150 250 Supply Current (Per Comparator) I MAX9141 200 320 CC µA MAX9140, VCM = VCC = 5V TA = -40°C to 85°C 165 300 MAX9140AA_ _ 400 MAX9142/MAX9144 165 300 MAX9141 only, SHDN = GND; VCC = VCM = 3V 12 30 Propagation Delay tPD+, t VCC = 3V, VOD = 10mV 40 ns PD- Differential Propagation Delay dtPD VOD = 10mV (Note 9) 2 ns Propagation Delay Skew VOD = 10mV (Note 10) 2 ns Logic Input-Voltage High VIH (Note 11) (VCC/2) +0.4 VCC/2 V Logic Input-Voltage Low VIL (Note 11) VCC/2 (VCC/2) -0.4 V Logic Input Current IIL, IIH VLOGIC = 0 to VCC (Note 11) 2 10 µA Data-to-Latch Setup Time tS (Note 12) 16 ns Latch-to-Data Hold Time tH (Note 12) 16 ns Latch Pulse Width tLPW (Note 12) 45 ns Latch Propagation Delay tLPD (Note 12) 60 ns Shutdown Enable Time (Note 13) 1 µs Shutdown Disable Time (Note 13) 5 µs Note 1: All devices are 100% production tested at TA = +25°C. Specifications over temperature are guaranteed by design. Note 2: Inferred from PSRR test. Note 3: Inferred from CMRR test. Note also that either or both inputs can be driven to the absolute maximum limit (0.3V beyond either supply rail) without damage or false output inversion. Note 4: VOS is defined as the center of the input-referred hysteresis zone. See Figure 1. Note 5: The input-referred trip points are the extremities of the differential input voltage required to make the comparator output change state. The difference between the upper and lower trip points is equal to the width of the input-referred hysteresis zone. See Figure 1. Note 6: The polarity of IB reverses direction as VCM approaches either supply rail. Note 7: Specified over the full common-mode voltage range (VCMR). Note 8: Specification is for current flowing into or out of the output pin for VOUT driven to any voltage from VCC to GND while the part is in shutdown. Note 9: Specified between any two channels in the MAX9142/MAX9144. Note 10: Specified as the difference between tPD+ and tPD- for any one comparator. Note 11: Applies to the MAX9141 only for both SHDN and LE. Note 12: Applies to the MAX9141 only. Comparator is active with LE driven high and is latched with LE driven low (VOD = 10mV). See Figure 2. Note 13: Applicable to the MAX9141 only. Comparator is active with the SHDN driven high and is shutdown with SHDN driven low. Shutdown enable time is the delay when the SHDN is driven high to the time the output is valid. Shutdown disable time is the delay when the SHDN is driven low to the time the comparator shuts down. www.maximintegrated.com Maxim Integrated │ 3
