Datasheet MAX6037 (Analog Devices) - 6
DescriptionLow-Power, Fixed and Adjustable Reference with Shutdown in SOT23
Pages / Page18 / 6 — Low-Power, Fixed and Adjustable Reference with Shutdown in SOT23
File Format / SizePDF / 439 Kb
Low-Power, Fixed and Adjustable Reference with Shutdown in SOT23 ELECTRICAL CHARACTERISTICS—MAX6037_30 (VOUT = 3.000V) (continued)
(VIN = VSHDN = +5V, IOUT = 0, COUT = 0.1µF, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
Output Impedance when ZOUT VIN = 5V, VSHDN = 0V 300 kΩ Disabled Capacitive-Load Stability COUT 0.02 1 µF
MAX6037
Range (Note 4)
INPUT
Supply Voltage Range VIN Guaranteed by line regulation test 3.2 5.5 V Quiescent Supply Current IIN 210 275 µA Shutdown Supply Current ISHDN VSHDN = 0V 0.05 500 nA
SHUTDOWN (
SHDN
Logic-High Input Voltage VENH 3.2V ≤ VIN ≤ 5.5V 2.0 V Logic-Low Input Voltage VENL 3.2V ≤ VIN ≤ 5.5V 0.8 V Logic-High Input Current IENH 3.2V ≤ VIN ≤ 5.5V, VSHDN = VIN -1000 0.15 +1000 nA Logic-Low Input Current IENL 3.2V ≤ VIN ≤ 5.5V, VSHDN = 0V -1000 0.05 +1000 nA
ELECTRICAL CHARACTERISTICS—MAX6037_33 (VOUT = 3.300V)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS OUTPUT
MAX6037A_33 (0.2%) 3.2934 3.300 3.3066 Output Voltage V MAX6037B_33 (0.3%) 3.2901 3.300 3.3099 OUT TA = +25°C V MAX6037C_33 (0.5%) 3.2855 3.300 3.3165 Output-Voltage Temperature MAX6037A_33 6 25 TCVOUT ppm/°C Coefficient (Note 2, 4) MAX6037B/C_33 6 50 Line Regulation ∆VOUT/∆VIN (VOUT + 0.2V) ≤ VIN ≤ 5.5V 0.0003 0.0133 %/V Sourcing: 0 ≤ IOUT ≤ 1mA 0.005 0.027 Sourcing: 1mA ≤ IOUT ≤ 5mA 0.002 0.027 Load Regulation ∆VOUT/∆IOUT %/mA Sinking: -1mA ≤ IOUT ≤ 0 0.02 0.212 Sinking: -5mA ≤ IOUT ≤ -1mA 0.01 0.212 Short to GND 33 OUT Short-Circuit Current ISC mA Short to IN 32 ISOURCE = 1mA 40 100 Dropout Voltage (Note 5) VIN - VOUT mV ISOURCE = 5mA 190 410 Thermal Hysteresis (Note 3) ∆VOUT/cycle 514 ppm Long-Term Stability ∆VOUT/time 1000h at TA = +25°C 133 ppm
6 _______________________________________________________________________________________
