Datasheet MAX6126 (Analog Devices) - 5
DescriptionUltra-High-Precision, Ultra-Low-Noise, Series Voltage Reference
Pages / Page28 / 5 — Electrical Characteristics—MAX6126_28 (VOUT = 2.800V) (continued). …
File Format / SizePDF / 4.0 Mb
Electrical Characteristics—MAX6126_28 (VOUT = 2.800V) (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
Electrical Characteristics—MAX6126_28 (VOUT = 2.800V) (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX6126 Ultra-High-Precision, Ultra-Low-Noise, Series Voltage Reference
(VIN = 5V, CLOAD = 0.1μF, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
Short to GND 160 OUT Short-Circuit Current ISC mA Short to IN 20 Thermal Hysteresis (Note 2) ΔVOUT/ cycle µMAX 80 ppm Long-Term Stability ΔVOUT/ time 1000hr at TA = +25°C µMAX 100 ppm/ 1000hr
DYNAMIC CHARACTERISTICS
f = 0.1Hz to 10Hz 1.45 µVP-P Noise Voltage eOUT f = 1kHz, CNR = 0 75 nV/√Hz f = 1kHz, CNR = 0.1µF 45 C Turn-On Settling Time t To VOUT = 0.01% of NR = 0 1 R final value ms CNR = 0.1µF 20 Capacitive-Load Stability Range CLOAD No sustained oscillations 0.1 to 10 µF
INPUT
Supply Voltage Range VIN Guaranteed by line-regulation test 3.0 12.6 V T Quiescent Supply Current I A = +25°C 380 550 IN µA TA = -40°C to +125°C 725
Electrical Characteristics—MAX6126_30 (VOUT = 3.000V)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS OUTPUT
Output Voltage VOUT TA = +25°C 3.000 V A grade SO -0.02 +0.02 B grade SO -0.06 +0.06 Output Voltage Accuracy Referred to VOUT, T % A = +25°C A grade µMAX -0.06 +0.06 B grade µMAX -0.1 +0.1 A grade SO 0.5 3 TA = -40°C to B grade SO 1 5 +85°C A grade µMAX 1 3 Output Voltage Temperature B grade µMAX 2 7 Coefficient (Note 1) TCVOUT ppm/°C A grade SO 1 5 TA = -40°C to B grade SO 2 10 +125°C A grade µMAX 2 5 B grade µMAX 3 12 www.maximintegrated.com Maxim Integrated │ 5
