Datasheet TS3702 (STMicroelectronics) - 3
DescriptionMicropower dual CMOS voltage comparators
Pages / Page11 / 3 — TS3702. Absolute maximum ratings and operating conditions. Table 1. …
File Format / SizePDF / 118 Kb
TS3702. Absolute maximum ratings and operating conditions. Table 1. Absolute maximum ratings. Symbol. Parameter. Value. Unit. Table 2
TS3702 Absolute maximum ratings and operating conditions Table 1 Absolute maximum ratings Symbol Parameter Value Unit Table 2
TS3702 Absolute maximum ratings and operating conditions 2 Absolute maximum ratings and operating conditions Table 1. Absolute maximum ratings Symbol Parameter Value Unit
V + CC Supply voltage (1) 18 V Vid Differential input voltage (2) ±18 V Vi Input voltage (3) 18 V Vo Output voltage 18 V Io Output current 20 mA IF Forward current in ESD protection diodes on input (4) 50 mA Power dissipation (5) DIP8 1250 pd mW SO8 710 TSSOP8 625 Tstg Storage temperature range -65 to +150 °C HBM: human body model(6) 400 V ESD MM: machine model(7) 50 V CDM: charged device model(8) 1.5 kV 1. All voltage values, except differential voltage, are with respect to network ground terminal. 2. Differential voltages are the non-inverting input terminal with respect to the inverting input terminal. 3. The magnitude of the input and the output voltages must never exceed the magnitude of the positive and negative supply voltages. 4. Guaranteed by design. 5. Pd is calculated with Tamb = +25°C, Tj = +150°C and Rthja = 100°C/W for DIP8 package Rthja = 175°C/W for SO8 package Rthja = 200°C/W for TSSOP8 package 6. Human body model: A 100pF capacitor is charged to the specified voltage, then discharged through a 1.5kΩ resistor between two pins of the device. This is done for all couples of connected pin combinations while the other pins are floating. 7. Machine model: A 200pF capacitor is charged to the specified voltage, then discharged directly between two pins of the device with no external series resistor (internal resistor < 5Ω). This is done for all couples of connected pin combinations while the other pins are floating. 8. Charged device model: all pins and the package are charged together to the specified voltage and then discharged directly to the ground through only one pin. This is done for all pins.
Table 2. Operating conditions Symbol Parameter Value Unit
Supply voltage V + CC TS3702C, TS3702I 2.7 to 16 V TS3702M 4 to 16 V + icm Common mode input voltage range 0 to VCC -1.5 V Operating free-air temperature range TS3702C 0 to +70 Toper °C TS3702I -40 to +125 TS3702M -55 to +125 3/11 Document Outline 1 Schematic diagram Figure 1. Schematic diagram (for 1/2 TS3702) 2 Absolute maximum ratings and operating conditions Table 1. Absolute maximum ratings Table 2. Operating conditions 3 Electrical characteristics Table 3. VCC+ = 3V, Vcc- = 0V, Tamb = 25˚C (unless otherwise specified) Table 4. VCC+ = 5V, Vcc- = 0V, Tamb = 25˚C (unless otherwise specified) 4 Package information 4.1 DIP8 package mechanical data 4.2 SO8 package mechanical data 4.3 TSSOP8 package mechanical data 5 Ordering information Table 5. Order codes 6 Revision history
