Datasheet NXS0506 (Nexperia) - 9
ManufacturerNexperia
DescriptionSD 3.0-compatible memory card integrated auto-direction control and level translator with EMI filter and ESD protection
Pages / Page17 / 9 — Nexperia. NXS0506. SD 3.0-compatible memory card integrated …
Revision31012022
File Format / SizePDF / 269 Kb
Nexperia. NXS0506. SD 3.0-compatible memory card integrated auto-direction control and level translator with EMI filter and
Nexperia NXS0506 SD 3.0-compatible memory card integrated auto-direction control and level translator with EMI filter and
link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9
Nexperia NXS0506 SD 3.0-compatible memory card integrated auto-direction control and level translator with EMI filter and ESD protection Symbol Parameter Conditions Tamb = -40 °C to 85 °C Unit Min Typ[1] Max Host-side to host-side propagation delay; CLKA to CLKFB
tpd propagation VCCA = 1.2 V; VCCB = 1.8 V [3] - 5.8 10 ns delay VCCA = 1.2 V; VCCB = 3.3 V [3] - 3.9 7.0 ns VCCA = 1.8 V; VCCB = 1.8 V [3] - 5.4 9.4 ns VCCA = 1.8 V; VCCB = 3.3 V [3] - 3.3 5.8 ns
Bus signal equivalent capacitance
CI/O input/output VI = 0 V; fi = 1 MHz; VCCA = 1.8 V; host side [4] - 5 - pF capacitance VI = 0 V; fi = 1 MHz; VCCB = 1.8 V; card side [4] - 12 - pF [1] Typical values are measured at Tamb = 25 °C. [2] tt is the same as tTHL and tTLH. [3] tpd is the same as tPLH and tPHL. [4] EMI filter line capacitance from I/O driver to pin; CI/O is guaranteed by design. VI VY input VM V GND X tf tr tPHL tPLH VOH VY output VM V V X OL tTHL tTLH aaa-034251 Measurement points are given in Table 10. VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 5. The input to output propagation delays, input rise and fall times and output transition times Table 10. Measurement points Supply voltage Input Output VCCA VCCB VI [1] VM [1] VM [2]
1.1 V to 1.95 V 1.7 V to 3.6 V VCCI 0.5VCCI 0.5VCCO [1] VCCI is the supply voltage associated with the input. [2] VCCO is the supply voltage associated with the output. NXS0506 All information provided in this document is subject to legal disclaimers. © Nexperia B.V. 2022. Al rights reserved
Product data sheet Rev. 1 — 31 January 2022 9 / 17
Document Outline 1. General description 2. Features and benefits 3. Applications 4. Ordering information 5. Marking 6. Block diagram 7. Functional diagram 8. Pinning information 8.1. Pinning 8.2. Pin description 9. Functional description 9.1. Level translator 9.2. Enable and direction control 9.3. Feedback clock channel 9.4. EMI filter 9.5. ESD protection 9.6. Pin and channel naming 10. Limiting values 11. Recommended operating conditions 12. Static characteristics 13. Dynamic characteristics 13.1. Level translator 14. Application information 14.1. PCB design guidelines 15. Design and assembly recommendations 15.1. PCB design guidelines 15.2. PCB assembly guidelines for Pb-free soldering 16. Package outline 17. Abbreviations 18. Revision history 19. Legal information Contents
