Datasheet BC337, BC337-25, BC337-40 (ON Semiconductor) - 5
Manufacturer | ON Semiconductor |
Description | Amplifier Transistors NPN Silicon |
Pages / Page | 8 / 5 — PACKAGE DIMENSIONS. TO−92 (TO−226). SCALE 1:1. SEATING. INCHES. … |
Revision | 8 |
File Format / Size | PDF / 187 Kb |
PACKAGE DIMENSIONS. TO−92 (TO−226). SCALE 1:1. SEATING. INCHES. MILLIMETERS. PLANE. DIM. MIN. MAX. X X. SECTION X−X. STYLES ON PAGE 2
MECHANICAL CASE OUTLINE
PACKAGE DIMENSIONS TO−92 (TO−226)
CASE 29−11
SCALE 1:1
ISSUE AM DATE 09 MAR 2007 1 1 2 2 3 3 STRAIGHT LEAD BENT LEAD BULK PACK TAPE & REEL AMMO PACK NOTES:
A B
STRAIGHT LEAD 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. BULK PACK 2. CONTROLLING DIMENSION: INCH. 3. CONTOUR OF PACKAGE BEYOND DIMENSION R
R
IS UNCONTROLLED. 4. LEAD DIMENSION IS UNCONTROLLED IN P AND
P
BEYOND DIMENSION K MINIMUM.
L SEATING INCHES MILLIMETERS PLANE K DIM MIN MAX MIN MAX A
0.175 0.205 4.45 5.20
B
0.170 0.210 4.32 5.33
C
0.125 0.165 3.18 4.19
D
0.016 0.021 0.407 0.533
D X X G
0.045 0.055 1.15 1.39
G H
0.095 0.105 2.42 2.66
J
0.015 0.020 0.39 0.50
H J K
0.500 --- 12.70 ---
V L
0.250 --- 6.35 ---
C N
0.080 0.105 2.04 2.66
SECTION X−X P
--- 0.100 --- 2.54
R
0.115 --- 2.93 ---
1 N V
0.135 --- 3.43 ---
N
NOTES:
A B
BENT LEAD 1. DIMENSIONING AND TOLERANCING PER
R
ASME Y14.5M, 1994. TAPE & REEL 2. CONTROLLING DIMENSION: MILLIMETERS. AMMO PACK 3. CONTOUR OF PACKAGE BEYOND DIMENSION R IS UNCONTROLLED. 4. LEAD DIMENSION IS UNCONTROLLED IN P
P
AND BEYOND DIMENSION K MINIMUM.
T MILLIMETERS SEATING K PLANE DIM MIN MAX A
4.45 5.20
B
4.32 5.33
C
3.18 4.19
D
0.40 0.54
D X X G
2.40 2.80
G J
0.39 0.50
K
12.70 ---
J N
2.04 2.66
V P
1.50 4.00
C R
2.93 ---
SECTION X−X V
3.43 ---
1 N STYLES ON PAGE 2 DOCUMENT NUMBER: 98ASB42022B
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed
STATUS: ON SEMICONDUCTOR STANDARD
versions are uncontrolled except when stamped
NEW STANDARD:
“CONTROLLED COPY” in red. © Semiconductor Components Industries, LLC, 2002
http://onsemi.com
Case Outline Number:
October, 2002 − Rev. 0 DESCRIPTION: TO−92 (TO−226) 1 PAGE XXX 1 OF 3
