Datasheet SBG3030CT, SBG3040CT, SBG3045CT (Diodes) - 2
Manufacturer | Diodes |
Description | 30A SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER |
Pages / Page | 5 / 2 — NOT RECOMMENDED FOR NEW DESIGN -. NO ALTERNATE PART. SBG3030CT - … |
File Format / Size | PDF / 195 Kb |
NOT RECOMMENDED FOR NEW DESIGN -. NO ALTERNATE PART. SBG3030CT - SBG3045CT. Maximum Ratings. SBG. Characteristic. Symbol. Unit. 3030CT
NOT RECOMMENDED FOR NEW DESIGN - NO ALTERNATE PART SBG3030CT - SBG3045CT Maximum Ratings
(@TA = +25°C, unless otherwise specified.) Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
SBG SBG SBG Characteristic Symbol Unit 3030CT 3040CT 3045CT
Peak Repetitive Reverse Voltage VRRM Working Peak Reverse Voltage VRWM 30 40 45 V DC Blocking Voltage (Note 2) VR RMS Reverse Voltage VR(RMS) 21 28 32 V Average Rectified Output Current @ TC = +100C IO 30 A Non-Repetitive Peak Forward Surge Current I 8.3ms Single Half Sine-wave Superimposed On Rated Load FSM 250 A
Thermal Characteristics Characteristic Symbol Value Unit
Typical Thermal Resistance Junction to Case (Note 3) RJC 1.5 °C/W Operating Temperature Range TJ -55 to +125 C Storage Temperature Range TSTG -55 to +150 C
Electrical Characteristics
Forward Voltage, Per Element @ IF = 15A, TC = +25C VFM 0.55 V Peak Reverse Current @ TJ = +25C 1.0 I mA at Rated DC Blocking Voltage (Note 2) @ T RM J = +100C 75 Typical Total Capacitance (Note 4) CT 420 pF Notes: 2. Short duration pulse test used to minimize self-heating effect. 3. Thermal resistance junction to case mounted on heatsink. 4. Measured at 1.0MHz and applied reverse voltage of 4.0V DC and per element. 30 ) A 100 ( ) T A Total Package N ( E T R N 24 R E U T = 25 C
R C J R U D 10 C R A D 18 Per Element W EI R FI O T F C S E U R 12 O E 1.0 E G N A A R T E N PULSE WIDTH V 6 A 2% Duty Cycle A T , S ) V NI I A( , F 0.1 I 0 0.1 0.3 0.5 0.7 0.9 1.1 0 50 100 150 V , INSTANTANEOUS FORWARD VOLTAGE (V) F T , CASE TEMPERATURE ( C) ° Fig. 2 Typical Forward Characteristics, Per Element C Fig. 1 Forward Derating Curve SBG3030CT - SBG3045CT 2 of 5 April 2018 Document number: DS30025 Rev. 9 - 3
www.diodes.com
© Diodes Incorporated
