Datasheet MAX6033 (Maxim) - 5
ManufacturerMaxim
DescriptionHigh-Precision, Low-Dropout SOT23 Series Voltage Reference
Pages / Page13 / 5 — Electrical Characteristics—VOUT = 4.096V. PARAMETER. SYMBOL. CONDITIONS. …
Electrical Characteristics—VOUT = 4.096V. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
Electrical Characteristics—VOUT = 4.096V PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX6033 High-Precision, Low-Dropout SOT23 Series Voltage Reference
(VIN = 5V, COUT = 0.1µF, IOUT = 0A, TA = TMIN to TMAX, unless otherwise specified. Typical values are at TA = +25°C.) (Note 1)
MAX6033A 4.0943 4.0960 4.0977 Output Voltage VOUT TA = +25°C MAX6033B 4.0878 4.0960 4.1042 V MAX6033C 4.0919 4.0960 4.1001 MAX6033A -0.04 +0.04 Output-Voltage Accuracy TA = +25°C MAX6033B -0.2 +0.2 % MAX6033C -0.1 +0.1 T MAX6033A A = -40°C to +85°C 1.5 7 TA = -40°C to +125°C 2.5 10 Output-Voltage Temperature TA = -40°C to +85°C 3 10 Coefficient TCVOUT MAX6033B ppm/°C TA = -40°C to +125°C 7 15 T MAX6033C A = -40°C to +85°C 6 20 TA = -40°C to +125°C 10 40 Input-Voltage Range VIN Inferred from line regulation specification 4.3 12.6 V T Line Regulation ∆VOUT/ A = +25°C 6 30 ∆V 4.3V ≤ VIN ≤ 12.6V µV/V IN TA = -40°C to +125°C 60 T Load Regulation ∆VOUT/ -100µA ≤ IOUT ≤ A = +25°C 0.002 0.08 ∆I mV/mA OUT 15mA TA = -40°C to +125°C 0.15 I Dropout Voltage (Note 2) V OUT = 1mA 0.02 0.2 DO ∆VOUT = 0.1% V IOUT = 10mA 0.2 0.4 TA = +25°C 40 60 Quiescent Supply Current IIN TA = -40°C to +85°C 75 µA TA = -40°C to +125°C 85 V Output Short-Circuit Current I OUT = 0V 90 SC mA VOUT = VIN -2 0.1Hz ≤ f ≤ 10Hz 32 µV Output-Voltage Noise en P-P 10Hz ≤ f ≤ 1kHz 22 µVRMS Turn-On Settling Time tON VOUT settles to ±0.01% of final value 800 µs Temperature Hysteresis (Note 3) 150 ppm Long-Term Stability ∆t = 1000hr 40 ppm www.maximintegrated.com Maxim Integrated │ 5 Document Outline _GoBack
