Datasheet MAX1595 (Maxim)
ManufacturerMaxim
DescriptionRegulated 3.3V/5.0V Step-Up/Step-Down Charge Pump
Pages / Page7 / 1 — Regulated 3.3V/5.0V Step-Up/Step-Down. Charge Pump. MAX1595. General …
File Format / SizePDF / 178 Kb
Regulated 3.3V/5.0V Step-Up/Step-Down. Charge Pump. MAX1595. General Description. Features
Datasheet MAX1595 Maxim
19-2107; Rev 3; 10/11
Regulated 3.3V/5.0V Step-Up/Step-Down Charge Pump MAX1595 General Description Features
The MAX1595 charge-pump regulator generates either o
Ultra-Small: Requires Only Three Ceramic
3.3V or 5V from a 1.8V to 5.5V input. The unique control
Capacitors
architecture allows the regulator to step up or step down the input voltage to maintain output regulation. The o
No Inductors Required
1MHz switching frequency, combined with a unique o
Up to 125mA Output Current
control scheme, allows the use of a ceramic capacitor as small as 1µF for 125mA of output current. The com- o
Regulated ±3% Output Voltage
plete regulator requires three external capacitors—no o
1MHz Switching Frequency
inductor is needed. The MAX1595 is specifically designed to serve as a high-power, high- efficiency aux- o
1.8V to 5.5V Input Voltage
iliary supply in applications that demand a compact o
220µA Quiescent Current
design. The MAX1595 is offered in space-saving 8-pin µMAX® and high-power 12-pin TQFN packages. o
0.1µA Shutdown Current Applications
o
Load Disconnect in Shutdown
White LED Power
Ordering Information
Flash Memory Supplies Battery-Powered Applications
PART TEMP RANGE PIN-PACKAGE
MAX1595EUA33+ -40°C to +85°C 8 µMAX Miniature Equipment MAX1595ETC33+ -40°C to +85°C 12 TQFN-EP* PCMCIA Cards MAX1595EUA50+ -40°C to +85°C 8 µMAX 3.3V to 5V Local Conversion Applications MAX1595ETC50+ -40°C to +85°C 12 TQFN-EP* Backup-Battery Boost Converters +Denotes a lead(Pb)-free/RoHS-compliant package. 3V to 5V GSM SIMM Cards *EP = Exposed pad.
Selector Guide
µMAX is a registered trademark of Maxim Integrated Products, Inc.
PART VOUT (V)** TOP M ARK
MAX1595EUA33+ 3.3 — MAX1595ETC33+ 3.3 AAEH
Typical Operating Circuit
MAX1595EUA50+ 5.0 — MAX1595ETC50+ 5.0 AAEI **Contact factory for other fixed-output voltages from 2.7V to 5.0V.
Pin Configurations
CXN CXP MAX1595 TOP VIEW INPUT IN OUT OUTPUT AOUT AOUT 1 8 OUT SHDN SHDN 2 7 CXP MAX1595 IN 3 6 CXN PGND GND GND 4 5 PGND µ
MAX Pin Configurations continued at end of data sheet. Maxim Integrated Products For pricing, delivery, and ordering information, please contact Maxim Direct at 1-888-629-4642, or visit Maxim’s website at www.maxim-ic.com.
